Author Topic: ( C3D ) Hourglass cursor in layer menu  (Read 4879 times)
  • Custom Title
« on: October 03, 2005, 10:21:54 AM »
Anyone having this ( hourglass cursor in layer pull-down menu ) happen in C3D?
jonesy
  • SuperMod
Re: ( C3D ) Hourglass cursor in layer menu
« Reply #1 on: October 03, 2005, 11:06:07 AM »
I used to have it in ADT 3.3. Cant say I've noticed it in 2004 tho'
  • Custom Title
« Reply #2 on: October 03, 2005, 11:17:03 AM »
It appears to be fixed in LDT, Map3D and AutoCAD all 2006.
I happens after I hit "Apply" on any of the modify dialogs.
Dinosaur
« Reply #3 on: October 03, 2005, 11:30:44 AM »
I get the same results as you with the pulldown style toolbar.  I never noticed it before because I keep mine docked to the side.  Everything acts normally with it there.
« Reply #4 on: October 03, 2005, 12:55:07 PM »
I see it quite regularly and as such it becomes a pain in the arse that I have to restart AutoCAD ... it makes selection of layers difficult .. at least it does with my cursor scheme.
MikePerry
« Reply #5 on: October 06, 2005, 01:20:22 PM »
Hi
Check out the following Technical Document on the Autodesk web site under the Knowledge Base section -
ID: TS51360 - Cursor changes to hourglass when drop-down list is selected
Have a good one, Mike
  • Custom Title
« Reply #6 on: October 06, 2005, 01:32:15 PM »
Hi
Sorry Mike, I don't even have a custom hatch pattern.
LE
« Reply #7 on: October 06, 2005, 01:36:55 PM »
I don't have or use that program.... but a guess.... are group filters created by default and are they to many in the drawing?
MikePerry
« Reply #8 on: October 06, 2005, 01:38:20 PM »
Hi Mark
It will occur even if you just go to the "Custom tab" in the Hatch dialog box (no Custom Hatch Pattern required).
Cheers, Mike
