Author Topic: Creating Surface from Text Spots  (Read 6418 times)
bmossman
« on: August 25, 2009, 09:56:13 AM »
I have spot elevations made up of just plain text with no "Z" values.  I could be here all day inserting points on top of the text. Is there a way to generate points from the text values?
Re: Creating Surface from Text Spots
« Reply #1 on: August 25, 2009, 10:01:46 AM »
Open a brand new file
use MAP to attach this file with the Spot Elevations in it as a source file
Perform a MAP QUERY against this file, change the Query type to REPORT mode.
use the expressions of .X,.Y, .TVALUE to extract the x,y, and z to  a report file
open this file with Excel, and save-as to CVS (don't ask why)
import the report file as Points, or use the terrain explorer to read from this point file to create your surface model.
Detach the source file
and have a nice day!
« Reply #2 on: August 25, 2009, 10:30:37 AM »
Can we see a screen shot of the dialog box, please? I can't make those expressions work.
thanks
« Reply #3 on: August 25, 2009, 10:40:40 AM »
Apologies, for the generalisation...that was more or less an abstract of the process...(bad help is probably worse than none)
the actual expressions
.X1
.Y1
^AcDbMText.Text.Contents    OR one could use .STRING
« Last Edit: August 25, 2009, 10:53:24 AM by mjfarrell »
« Reply #4 on: August 25, 2009, 10:41:46 AM »
thanks
are you and the Bmossman working together there Chief?
« Reply #5 on: August 25, 2009, 10:52:35 AM »
Not a problem. I've never tried that before. I can remember a time or two when I could have used that so I thought I'd give it a try.
Not having any luck with the report, i'll study the doc's a bit more.
thanks
« Reply #6 on: August 25, 2009, 10:52:48 AM »
thanks
Nope! :-)
« Reply #7 on: August 25, 2009, 10:55:08 AM »
thanks
what part is or isn't working for you?  other than my misdirection on the expression values to use?
« Reply #8 on: August 25, 2009, 11:05:25 AM »
thanks
When I used 'X1' and 'Y1' I didn't get any values. I have since figured it out, sort of. I can get the X,Y values from the MTEXT object just fine. As long as the MTEXT is inserted in the proper location, or some how associated with a point for instance my method would work.
« Reply #9 on: August 25, 2009, 11:06:51 AM »
Why not just save the file as <filename>.csv ? It is already comma delimited. Well mine is! :-)
« Reply #10 on: August 25, 2009, 11:10:58 AM »
This is what I have.
« Reply #11 on: August 25, 2009, 11:11:45 AM »
Correct, as in the case of a(n) aerial survey drawing, this process is slightly thwarted, when they move the elevation text associated with the elevation node around.  However in most instances I have found that the node has the correct .Z and the text location is a non-issue. There have been instances where it is easier to use the liner elements, breaklines and contours, to extract surface point elevations from.   The process is similar, it all depends on the data one has to work with.
« Reply #12 on: August 25, 2009, 11:16:04 AM »
I asked you to NOT ask why....now you've gotten me all riled up.
Because, when you attempt to insert that CSV file you will get an error...because about 7(Seven) versions ago autodesk broke the report writer, and it doesn't write out a clean ascii file that one can use to import points.
I've been ranting like a mad dog all this time about it, and they wont fix it....
« Reply #13 on: August 25, 2009, 11:17:44 AM »
Indeed. None the less that is a pretty neat trick! I'll try and remember that one for later use. :-)
« Reply #14 on: August 25, 2009, 11:18:51 AM »
You need a LOCATION statement as well as a property condition.
It doesn't know where in the file to look without that...
