Author Topic: pop0 to a key  (Read 2492 times)
Hangman
pop0 to a key
« on: May 11, 2005, 03:43:15 PM »
Afternoon all,
this is sort of a silly question, not sure if it would even go to this forum.
But, here it is:
Is it possible to set the pop0 from the acad.mns file to a key, like S for example.
***POP0
**SNAP
               [&Object Snap Cursor Menu]
ID_Tracking    [Temporary trac&k point]_tt
ID_From        [&From]_from
ID_MidTwoPts   [Mid Bet&ween 2 Points]_m2p
ID_MnPointFi   [->Poin&t Filters]
ID_PointFilx     [.X].X
ID_PointFily     [.Y].Y
ID_PointFilz     [.Z].Z
ID_PointFixy     [.XY].XY
ID_PointFixz     [.XZ].XZ
ID_PointFiyz     [<-.YZ].YZ
ID_OsnapEndp   [&Endpoint]_endp
ID_OsnapMidp   [&Midpoint]_mid
ID_OsnapInte   [&Intersection]_int
ID_OsnapAppa   [&Apparent Intersect]_appint
ID_OsnapExte   [E&xtension]_ext
ID_OsnapCent   [&Center]_cen
ID_OsnapQuad   [&Quadrant]_qua
ID_OsnapTang   [Tan&gent]_tan
ID_OsnapPerp   [&Perpendicular]_per
ID_OsnapPara   [Para&llel]_par
ID_OsnapNode   [No&de]_nod
ID_OsnapInse   [In&sert]_ins
ID_OsnapNear   [Nea&rest]_nea
ID_OsnapNone   [&None]_non
ID_Osnap       [&Osnap Settings...]'_+dsettings 2
I want to be able to hit the S key and the get menu rather than the shift+right click.
Any ideas on how this could be done ???
pop0 to a key
« Reply #1 on: May 11, 2005, 04:17:44 PM »
Something like :
(defun c:s ()
  (menucmd "P0=POP0")
  (menucmd "P0=*")
pop0 to a key
« Reply #2 on: May 11, 2005, 04:18:46 PM »
Though you will still have to hit enter or the space bar.
Hangman
pop0 to a key
« Reply #3 on: May 11, 2005, 05:38:44 PM »
That's cool, I couldn't figure out the "P0=  you have in the line.  Thanks.
By the way, where are you getting the P0= from anyway ???
rude dog
pop0 to a key
« Reply #4 on: May 11, 2005, 07:36:16 PM »
I also added this to minz after seeing my bud use it
ID_PointFil@     [@]@
and of course <mbuttonpan> is set to <0>
