Code Red => AutoLISP (Vanilla / Visual) => Topic started by: kozmos on December 14, 2023, 07:30:22 AM
I tried to use command (and command-s and vl-cmdf) to call Join command, and passing a preselected objects to these commands, but they do not work. Anyone has any ideas how to fix it?
(Defun c:TT (/ ss)
(if (setq ss (ssget))
(command "_.join" ss "")
Calling C:TT will not join the selected lines.
I'm not sure why, but this seems to work:
(defun c:join
-the
-swamp
(/ ss
The (command) version is different from the pure command.
Try (command "_.join") and see what it ask...
with somne search online, I found the answer: https://www.cadtutor.net/forum/topic/55336-join-command/
need to call (initcommandversion) before calling "_.join"
