Author Topic: BlockTableRecord.IsFromExternalReference always false?  (Read 2495 times)
sinc
« on: December 26, 2008, 01:47:44 AM »
For some reason, every call to IsFromExternalReference is returning false, even when the BlockTableRecord is an XREF.
Has anyone ever seen this?  I'm sure this used to work, but it's not working for me now...
Re: BlockTableRecord.IsFromExternalReference always false?
« Reply #1 on: December 26, 2008, 03:53:54 AM »
This works for me Sinc ...
Command: _XATTACH
Overlay Xref "SECT-HEAD-1R": F:\_kdub_testing\Dwgs\SECT-HEAD-1R.dwg
"SECT-HEAD-1R" loaded.
Command: _XATTACH
Overlay Xref "Alphabet Soup": F:\_kdub_testing\nest-0\Alphabet Soup.dwg
"Alphabet Soup" loaded.
Command: ListXrefs
Found XREF : SECT-HEAD-1R
Found XREF : Alphabet Soup
[CommandMethod("ListXrefs")]
public static void ListXrefs()
    Document doc = AcadApp.DocumentManager.MdiActiveDocument;
    Editor ed = doc.Editor;
        BlockTable bt = tr.GetObject(
            db.BlockTableId, OpenMode.ForRead) as BlockTable;
        BlockTableRecord btr = tr.GetObject(
            bt[BlockTableRecord.ModelSpace], OpenMode.ForRead) as BlockTableRecord;
        foreach (ObjectId objId in btr)
            DBObject dbObj = tr.GetObject(
                objId, OpenMode.ForRead);
            BlockReference blkRef = dbObj as BlockReference;
            if (blkRef != null)
                BlockTableRecord blkTblRecord = tr.GetObject(
                    blkRef.BlockTableRecord, OpenMode.ForRead) as BlockTableRecord;
                if (blkTblRecord.IsFromExternalReference == true)
                    ed.WriteMessage("\nFound XREF : " + blkTblRecord.Name);
        tr.Commit();
« Last Edit: December 26, 2008, 03:59:00 AM by Kerry Brown »
sinc
« Reply #2 on: December 26, 2008, 11:37:11 AM »
Thanks, Kerry.
I was being brain-dead.  Well, I when I was working on this last night, it was around midnight, after two days of Christmas celebrations.  Probably not the best time to be coding.  :)
I had my BlockReference (br), and I was trying to do this:
BlockTableRecord btr = tr.GetObject(br.OwnerId, OpenMode.ForRead, false) as BlockTableRecord;
instead of this:
BlockTableRecord btr = tr.GetObject(br.BlockTableRecord, OpenMode.ForRead, false) as BlockTableRecord;
After I fixed that, everything is happy again.
I knew I had been using this and everything was OK, so I couldn't figure out what was going wrong.  But I was in one of those modes where I was looking all around the problem without seeing it.  Got it now, though.  Thanks!
« Reply #3 on: December 26, 2008, 08:27:25 PM »
....................   But I was in one of those modes where I was looking all around the problem without seeing it.  .............
I can't imagine anyone who couldn't honestly say the same ..
