Author Topic: System variable for publishing  (Read 1370 times)
HasanCAD
« on: November 25, 2013, 04:11:55 AM »
Hi All
I am coding a lisp to arrange the standard. I am searching for system variables related to publishing
What I collected
AUTODWFPUBLISH
AUTOMATICPUB
PUBLISHHATCH
PUBLISHCOLLATE
PUBLISHALLSHEETS
Is there any other SV related to publishing?
irneb
Re: System variable for publishing
« Reply #1 on: November 27, 2013, 01:00:09 AM »
I think there might be others in registry (i.e. Environment Variables). E.g.:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.1\ACAD-D001:409\Profiles\<<Unnamed Profile>>\Dialogs\AcPublishDlg\DefaultDwfFormat
Note this is under the profile, so you might just want to export/import a profile to have it match across different PC's / users.
Another thing is ETransmit Setups. Those are saved under sub-folders of:
HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.1\ACAD-D001:409\ETransmit\setups
Note these registry paths are for 2014 Vanilla, might be slightly different for other versions / verticals.
