Author Topic: Reading and Saving Attribute values. ala DBX..  (Read 10851 times)
It's Alive!
  • Retired
  • AKA Daniel
Re: Reading and Saving Attribute values. ala DBX..
« Reply #15 on: August 24, 2009, 08:39:59 AM »
here is an ARX version, probably not any faster since IO is the time consuming item.
  static void ArxBlockEx_doit(void)
    clock_t start, end;
    double diff;
    start = clock();
    for(int i = 0 ; i < 500; i++)
      std::auto_ptr<AcDbDatabase> pDb (new AcDbDatabase(false , true));
      pDb->readDwgFile(_T("C:\\Test20090823.dwg"),  _SH_DENYNO ,false);
      GetAttributesBench_doit(&(*pDb), _T("BBL_V8"));
      pDb->closeInput(true);
    end = clock();
    diff = ((double)(end - start)) / CLOCKS_PER_SEC;
    acutPrintf( _T("\n%2.3f seconds\n"), diff);
  static void GetAttributesBench_doit(AcDbDatabase *pDatabase, const CString &name)
    Acad::ErrorStatus es;
    std::wofstream out(_T("C:\\Test20090823.txt"));
    AcDbBlockTablePointer pBlockTable(pDatabase,AcDb::kForRead);
    if(pBlockTable.openStatus() != eOk) return;
    if(!pBlockTable->has(name)) return;
    AcDbObjectId blkid;
    if(pBlockTable->getAt(name,blkid) != eOk) return;
    AcDbBlockTableRecordPointer pTableRecord(blkid,AcDb::kForRead);
    if(pTableRecord.openStatus() != eOk) return;
    if (pTableRecord->hasAttributeDefinitions() == Adesk::kTrue)
      AcDbObjectIdArray blockReferenceIds;
      pTableRecord->getBlockReferenceIds(blockReferenceIds);
      for(int i = 0 ; i < blockReferenceIds.length() ; i++)
        AcDbObjectPointer<AcDbBlockReference> pBlockReference
          (blockReferenceIds[i] , AcDb::kForRead,Adesk::kFalse);
        out << "\n";
        std::auto_ptr<AcDbObjectIterator>
          pAttributeIterator(pBlockReference->attributeIterator());
        for (pAttributeIterator->start();
            !pAttributeIterator->done();
            pAttributeIterator->step())
          AcDbObjectPointer<AcDbAttribute> pAttribute
            (pAttributeIterator->objectId(),AcDb::kForRead);
          if(pAttribute.openStatus() == eOk)
            out << "("<<  pAttribute->tag() << "." << pAttribute->textString() << ")";
    out.close();
« Reply #16 on: August 24, 2009, 06:11:25 PM »
Times on a machine I'm using at the moment:
Lisp = 44.594 secs.
C# Original = 27.140625 secs
C# New = 22.203125 secs
New code:
            StringBuilder sb = new StringBuilder();
Interesting huh?
yep .. I'll have a look tonight at home Glenn.
Thanks for the input.
Dan,
Which arx build is that for ?
It's Alive!
  • Retired
  • AKA Daniel
« Reply #17 on: August 24, 2009, 06:13:36 PM »
Sorry, for 07 - 09  x32
« Reply #18 on: August 24, 2009, 08:33:04 PM »
Sorry,  ...
Don't be.
[geek]
I have the technology.
[/geek]
would have liked to test in 2010, but heh !  :wink:
It's Alive!
  • Retired
  • AKA Daniel
« Reply #19 on: August 24, 2009, 08:42:35 PM »
Sorry,  ...
Don't be.
[geek]
[/geek]
64 or 32 bit?   :laugh:
« Reply #20 on: August 24, 2009, 08:43:14 PM »
32 this week :)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #21 on: August 24, 2009, 08:54:35 PM »
here is both and the solution.
What is interesting is that 2010x64 is a third slower than 07x32 at this operation
« Reply #22 on: August 25, 2009, 06:27:35 AM »
Thanks Dan, I'll have a play on the weekend.
