Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
OFFSET polylign 3D
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: OFFSET polylign 3D (Read 1145 times)
clotho
Guest
OFFSET polylign 3D
on:
June 28, 2016, 07:21:32 AM »
Hi every body,
Please can any one give me a lisp to offset a 3D polylign.
Thank you in advance
Logged
ChrisCarlson
Guest
Re: OFFSET polylign 3D
Reply #1 on:
June 28, 2016, 07:56:58 AM »
No
http://lmgtfy.com/?q=AutoLISP+3D+Polyline+Offset
Logged
rkmcswain
Swamp Rat
WWW
Reply #2 on:
June 28, 2016, 08:56:40 AM »
Take a look:
http://www.cadtutor.net/forum/showthread.php?5322-How-do-I-offset-3d-Polyline
Logged
R.K. McSwain
twitter
MSTG007
Gator
I can't remeber what I already asked! I need help!
Reply #3 on:
June 28, 2016, 11:29:05 AM »
Quote from: ChrisCarlson on June 28, 2016, 07:56:58 AM
No
That IMGTFY.com is pretty cool.
Logged
Civil3D 2020
ribarm
Gator
Marko Ribar, architect
WWW
Reply #4 on:
June 28, 2016, 10:33:28 PM »
If nothing from above posted doesn't suit you, I'd convert 3d polyline to 3d spline and apply something from here :
https://www.theswamp.org/index.php?topic=51111.msg563254#msg563254
To convert 3d polyline to 3d spline, try something like this :
Code - Auto/Visual Lisp:
[Select]
defun
c:3p2spl
*error*
line2spl loop pl e s ss sss
vl-load-com
defun
*error*
msg
vla-endundomark
vla-get-activedocument
vlax-get-acad-object
if
msg
prompt
msg
princ
defun
line2spl
e
sp ep d
setq
sp
cdr
assoc
10
entget
e
ep
cdr
assoc
11
entget
e
d
distance
sp ep
entdel
e
entmakex
list
0
"SPLINE"
100
"AcDbEntity"
100
"AcDbSpline"
210
0.0
0.0
1.0
71
1
73
2
42
. 1.0e
010
43
. 1.0e
010
40
0.0
40
0.0
cons
40
d
cons
40
d
cons
10
sp
cons
10
ep
vla-startundomark
setq
loop T
setq
sss
ssget
"_I"
if
and
sss
eq
cdr
assoc
0
entget
setq
pl
ssname
sss
0
"POLYLINE"
7
cdr
assoc
70
entget
pl
10
setq
loop
nil
while
loop
setq
pl
car
entsel
\n
Pick 3DPOLYLINE to convert it to SPLINE"
if
and
pl
eq
cdr
assoc
0
entget
pl
"POLYLINE"
7
cdr
assoc
70
entget
pl
10
setq
loop
nil
setq
e
entlast
command
"_.EXPLODE"
pl
while
getvar
'cmdactive
0
command
setq
ss
ssadd
while
setq
e
entnext
e
if
eq
cdr
assoc
0
entget
e
"LINE"
progn
setq
s
line2spl e
ssadd
s ss
command
"_.JOIN"
ssname
ss
0
ss
while
getvar
'cmdactive
0
command
*error*
nil
HTH, M.R.
Logged
Marko Ribar, d.i.a.
(graduated engineer of architecture)
M.R. on Youtube
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
OFFSET polylign 3D
