Code Red => AutoLISP (Vanilla / Visual) => Topic started by: jmaeding on August 08, 2006, 05:46:03 PM
(Posted in adesk customization group also)
I want to replace an existing entity with another, and put the new one at the exact same draworder.
To get the draworder of the existing entity, I have to use the getfulldraworder method I believe.
Once I have the list, I can determine what object is above me so I use that in the MoveBelow method.
I am this far with getting it:
(setq space (vla-get-modelspace (vla-get-activedocument (vlax-get-acad-object))))
(setq extdict (vla-getextensiondictionary space))
(if (not (zerop (vla-get-count extdict)))
(setq sorttbl (vla-getobject extdict "acad_sortents"))
(setq sorttbl (vla-addobject extdict "acad_sortents" "acdbsortentstable"))
(setq allorder (vla-getfulldraworder sorttbl space :vlax-false))
but no go, I get nil for allorder...any ideas
I just noticed that the SortEntsDictionary has a SwapMember method. If you have the entity names, then you can swap them, no need to find the full order (which I haven't been able to do either).
SwapOrder Method
Swaps the draw order positions of two objects.
See Also | Example
Signature
object.SwapOrder (Object1, Object2)
object
SortentsTable
The object or objects this method applies to.
Object1
AcadEntity; the first object.
Object2
AcadEntity; the second object.
It worked for me. I drew a line, and then a rectangle, and then I hatched the rectangle. I used the draw order command, and brought it all to front. The hatch still on top. I got the object id for the line, and the hatch. I swaped them in the dictionary, and after a regen the line shows over the hatch.
Hope that helps.
Yep, this is one of those cases where the supplied argument (you used space above) is an OUTPUT variable.....this is more what you want:
(vla-getfulldraworder sorttbl 'allorder :vlax-false)
(setq allList (vlax-safearray->list allorder))
Good one Jeff. I don't know if I would have ever caught that one.
ahhh, grasshoppper!
Thanks again, hope you make it to AU this year!
