Author Topic: Find 2 nearest points from a variant-list to a startpoint  (Read 1288 times)
Peter2
« on: August 16, 2017, 01:29:09 PM »
I have a startpoint with coords 10,15,0
Then I have some points, originally in a variant, but converted to list:
(10 12 10 18 9 12 8 5 7 12)
I have to find the 2 points which are the nearest to my startpoint. It's obviously not insolvable, but does anyone knows an existing solution?
Peter
BricsCAD V23
Re: Find 2 nearest points from a variant-list to a startpoint
« Reply #1 on: August 16, 2017, 01:42:16 PM »
  1. (vl-sort listofpoints '(lambda (a b) (< (distance basepoint a) (distance basepoint b))))
The first two points in the sorted list are what you want. (car ..) (cadr ..)
DEVITG
« Reply #2 on: August 16, 2017, 07:46:48 PM »
Peter , your start point is some XYZ , and the others no way , it could be XYZ but it are 10 values
Peter2
« Reply #3 on: August 17, 2017, 09:03:34 AM »
Thanks to both  :-)
Peter
BricsCAD V23
