Author Topic: Looking for app/routine  (Read 1324 times)
nobody
  • .net stuff
« on: October 17, 2016, 01:41:04 AM »
Anyone know of a routine that will set the ends of arcs, lines, polylines to elevations of points at their same location? Hoping to save the effort of having to write it
lamarn
Re: Looking for app/routine
« Reply #1 on: October 17, 2016, 02:48:30 AM »
What about LM entopo?
Design is something you should do with both hands. My 2d hand , my 3d hand ..
ribarm
  • Marko Ribar, architect
« Reply #2 on: October 17, 2016, 03:42:29 AM »
Untested...
(defun c:curves2elevbypts ( / *error* *adoc* ssc ssp i p pl k c sp ep spn epn en e )
  (defun *error* ( m )
    (vla-endundomark *adoc*)
    (if m
      (prompt m)
  (vla-startundomark (setq *adoc* (vla-get-activedocument (vlax-get-acad-object))))
  (prompt "\nSelect curves...")
  (setq ssc (ssget "_:L" '((0 . "*POLYLINE,SPLINE,ELLIPSE,ARC,LINE"))))
  (while (or (not ssc) (not (vl-every '(lambda ( x / minp maxp ) (progn (vla-getboundingbox (vlax-ename->vla-object x) 'minp 'maxp) (equal (caddr (safearray-value minp)) (caddr (safearray-value maxp)) 1e-6))) (vl-remove-if 'listp (mapcar 'cadr (ssnamex ssc))))))
    (prompt "\nEmpty sel.set or some of selected entities not in plane parallel to WCS... Retry selecting curves...")
  (prompt "\nSelect points in 3D as projections of ends of curves to reposition curves according to them...")
  (setq ssp (ssget '((0 . "POINT"))))
  (while (not ssp)
    (prompt "\nEmpty sel.set... Retry selecting points...")
  (repeat (setq i (sslength ssp))
    (setq p (cdr (assoc 10 (entget (ssname ssp (setq i (1- i)))))))
    (setq pl (cons p pl))
  (setq k 0)
  (repeat (setq i (sslength ssc))
    (setq c (ssname ssc (setq i (1- i))))
    (setq sp (vlax-curve-getstartpoint c))
    (setq ep (vlax-curve-getendpoint c))
    (setq spn (car (vl-member-if '(lambda ( x ) (equal (mapcar '+ '(0.0 0.0) sp) (mapcar '+ '(0.0 0.0) x) 1e-6)) pl)))
    (setq epn (car (vl-member-if '(lambda ( x ) (equal (mapcar '+ '(0.0 0.0) ep) (mapcar '+ '(0.0 0.0) x) 1e-6)) pl)))
      ( (and spn epn)
        (setq en (/ (+ (caddr spn) (caddr epn)) 2.0))
        (setq e (/ (+ (caddr sp) (caddr ep)) 2.0))
        (vla-move (vlax-ename->vla-object c) (vlax-3d-point (list 0.0 0.0 e)) (vlax-3d-point (list 0.0 0.0 en)))
      ( (and spn (not epn))
        (setq en (caddr spn))
        (setq e (caddr sp))
      ( (and epn (not spn))
        (setq en (caddr epn))
        (setq e (caddr ep))
      ( t
        (setq k (1+ k))
  (prompt "\nTotal : ")(princ k)(prompt " curves that don't have matching points and haven't been moved...")
  (*error* nil)
HTH, M.R.
« Last Edit: October 17, 2016, 03:53:40 AM by ribarm »
M.R. on Youtube
nobody
  • .net stuff
« Reply #3 on: October 19, 2016, 02:58:48 AM »
Thank you!
