I'm using all of this to be a dynamic block update:
Select block, right click, select "Update Block..." from shortcut menu.
Code will determine the block name, block type (used for setting the path), then insert the block from the server, cancel the insert, and update the attributes:
-insert
Titleblock-Sheet_Info-24x36=Z:/Main/Blocks/Titleblock/Titleblock-Sheet_Info-24x36.dwg
(command)
attsync
name
bname
