Author Topic: Using Object Data to label linework  (Read 4788 times)
alanjt
  • Standby for witty remark...
Re: Using Object Data to label linework
« Reply #15 on: July 07, 2016, 10:58:33 AM »
That's only happened to me on 3 projects in the past 10 years, FWIW.
Cheers
snap snap snap snap snap snap
                                     snap
                                snap
                           snap
                      snap
                 snap
            snap
       snap
  snap
Dropbox
« Reply #16 on: July 07, 2016, 11:03:09 AM »
Once I'm done extracting the Object Data I need, I usually get rid of it to keep the drawing size as small as possible:
This seems counter productive to me.  I think of all the time wasted putting object data onto the objects, only to have it deleted?
What happens when and or if that object data is ever needed again?
Then I just go back to the 'source' drawing where I've already imported the County's GIS/Shapefile data with Object Data, and cull what I need, of course (i.e., project length changes, etc.)... Otherwise, I can simply run MAPIMPORT as needed (i.e., newer Shapefile is available, etc.)... That's only happened to me on 3 projects in the past 10 years, FWIW.
Cheers
Now that I see where your 'data' is coming from, that clears up the question of why you delete the object data.
A lot of the object data we deal with here is created, and added by us, so removing it seemed a foreign concept to me.
Thanks for the clarification.
« Reply #17 on: July 07, 2016, 11:03:45 AM »
Cheers
                                     snap
                                snap
                           snap
                      snap
                 snap
            snap
       snap
  snap
There was no SNAP there, or are you just being overly childish today?
Surprised you didn't try to type an "Around the world and behind my back snap" that would have been far more impressive.  equally childish, but more impressive to be sure.
alanjt
« Reply #18 on: July 07, 2016, 11:10:02 AM »
Cheers
                                     snap
                                snap
                           snap
                      snap
                 snap
            snap
       snap
  snap
Just being overly childish and joking around. Lighten up.
Dropbox
BlackBox
« Reply #19 on: July 07, 2016, 11:19:10 AM »
No worries, MJF; now that I understand where your OD originates, I understand why you asked.
Cheers
BlackBox
« Reply #20 on: July 07, 2016, 11:22:27 AM »
Cheers
                                     snap
                                snap
                           snap
                      snap
                 snap
            snap
       snap
  snap
 :-D  :mrgreen:  :angel:
alanjt
« Reply #21 on: August 02, 2016, 05:09:13 PM »
Adding to thread for next person...
https://knowledge.autodesk.com/support/autocad-civil-3d/troubleshooting/caas/sfdcarticles/sfdcarticles/Importing-ESRI-Shape-files-and-label-features-using-Display-Manager-s.html
@Michael: Building on this post, is it possible to have it label with an expression as to include more than one field, like you can when linking to SHP data with MapWSpace?
« Last Edit: August 04, 2016, 09:10:02 AM by alanjt »
Dropbox
