Author Topic: Matrix3d and TransformBy help  (Read 56883 times)
Re: Matrix3d and TransformBy help
« Reply #75 on: August 05, 2008, 10:31:02 AM »
(Dan, is that you on the avatar?...)
No that’s  Ted Cassidy (AKA Lurch)  as “RUK” in  "Star Trek, What Are Little Girls Made Of?" (1966)
is that you in yours?
Spike Wilbury
« Reply #76 on: August 05, 2008, 10:33:27 AM »
es muy bueno  :lol:
Good!!!, does not crash and works just on rectangular faces solids... or cubes ones
Spike Wilbury
« Reply #77 on: August 05, 2008, 10:34:40 AM »
He he... I knew.... sorry
That old guy is me. :)
Chuck Gabriel
« Reply #78 on: August 05, 2008, 10:36:16 AM »
He's lying.  That's Wolfgang Puck. :lmao:
« Reply #79 on: August 05, 2008, 10:37:49 AM »
es muy bueno  :lol:
It will process any solid that has at least two edges that are perpendicular, still working on Mick’s idea
Spike Wilbury
« Reply #80 on: August 05, 2008, 10:38:09 AM »
Dang!!!!,...... I knew it....  :lmao:
Spike Wilbury
« Reply #81 on: August 05, 2008, 10:41:48 AM »
es muy bueno  :lol:
I see, I ran the tests on simple and complex cubes solids.... thanks.
I will try to continue with mine....
Spike Wilbury
« Reply #82 on: August 05, 2008, 11:13:39 AM »
Spike Wilbury
« Reply #84 on: August 08, 2008, 10:06:12 AM »
Is there by any chance to upload here some 3d solid samples (complex/simple), that I can use to run tests ?
Thanks.
Below is a test to one of the solid posted here, the oriented bounding box is shown in green:
« Reply #85 on: August 08, 2008, 06:40:57 PM »
Try this one Luis, this is a classic case of when the wrong edge could give invalid results.
Note: the length should be perp the the I beam section.
- John Carmack
- J.R.R. Tolkien
« Reply #86 on: August 08, 2008, 06:55:27 PM »
This nect one's a bit contrived but we can get even stranger section cuts at times.
- John Carmack
- J.R.R. Tolkien
Spike Wilbury
« Reply #87 on: August 08, 2008, 06:56:02 PM »
This is the result...
« Reply #88 on: August 08, 2008, 06:57:09 PM »
If you get the next one we may have a winner :D, nice work Luis!
- John Carmack
- J.R.R. Tolkien
« Reply #89 on: August 08, 2008, 07:03:30 PM »
No prob's, after posting the first one I realised that the measured edge was the longest edge even though the depth of the beam was greater. The thing is, when looping through the edges it won't get the height, only the length of the beam web edge which is well short of the length, that's why I posted the second one ;)
- John Carmack
- J.R.R. Tolkien
