I was recommended posting on here by a user of the Autodesk Community Forums. Hopefully, someone may be up for the challenge.... ?
My task is to 'clean-up' 3D topographic survey drawings. In doing so I need to thin out areas of densely overlapping text. These may not always be on the same layer. I am in search of a routine that will do this for me automatically.
The routine will need to look at each piece of text throughout the drawing in turn and if it's boundary is overlapping another, then cross check with a reference table as to it's weight (importance). The higher the importance, the result being that it remains and the other is deleted. Those with equal weights, it does not matter which remains. The reference table would need to be created by the user beforehand but would remain the same for all occasions and so could be stored locally as a text file etc.
Anyone know of anything that can do this, or fancy having a go?
If you need any further info, please give me a shout.
Many thanks.
Rroger_D
