Author Topic: Convert BricsCAD's LISP to run on AutoCAD  (Read 2804 times)
ctrlaltdel
« on: August 24, 2016, 11:03:35 AM »
This LISP runs on BricsCAD but has an error when running on AutoCAD 2014.
Please help to covert the below LISP to run on AutoCAD 2014.
(defun c:test ( / nentselLst nestLevel)
      (setq nentselLst (nentsel))
      (= 4 (length nentselLst))
      (<= 0 (setq nestLevel (- (length (cadddr nentselLst)) 2)))
      (setvar 'cmdecho 0)
      (command "_.-refedit" (list (last (cadddr nentselLst)) (cadr nentselLst)))
      (repeat nestLevel (command "_next"))
      (command "_ok" "_all" "_yes")
      (setvar 'cmdecho 1)
Error when running this LISP on AutoCAD 2014
Command: test
Select object:
*Invalid selection*
Expects a single object.
Cannot invoke (command) from *error* without prior call to (*push-error-using-command*).
Converting (command) calls to (command-s) is recommended.
Select reference: *Cancel*
Command: *Cancel*
ChrisCarlson
Re: Convert BricsCAD's LISP to run on AutoCAD
« Reply #1 on: August 24, 2016, 11:34:44 AM »
What happens if you restart AutoCAD and run this for the first time?
ctrlaltdel
« Reply #2 on: August 24, 2016, 11:41:09 AM »
Tested at work & home. Same problem.
ChrisCarlson
« Reply #3 on: August 24, 2016, 11:48:24 AM »
I can't test it as I do not deal with references but some trouble shooting
1) Try command-s instead of command
ctrlaltdel
« Reply #4 on: August 24, 2016, 11:55:15 AM »
I did that eariler, on someone's advise.
Change the LISP as suggested. But no go. Not sure if its still due to BricsCAD incompatibility or the code is not right, though the writer said it worked in BricsCAD
      (setvar 'cmdecho 0)
      (command-s "_.-refedit" (list (last (cadddr nentselLst)) (cadr nentselLst)))
      (repeat nestLevel (command-s "_next"))
      (command-s "_ok" "_all" "_yes")
      (setvar 'cmdecho 1)
After I click the entity, it was suppose to bring me to a block in-place mode of a block level but nothing happend
Command: test
Select object:                    <<<<<I select entity but nothing happend, instead runs the usual refedit command
Select reference: *Cancel*    <<<<<AT this point if i select anything, it just runs the usual refedit command
Command:
Command: *Cancel*
danallen
« Reply #5 on: August 24, 2016, 01:15:45 PM »
Have you tried typing each command in the lisp to see if the sequence of prompts / inputs is correct? example: -refedt (enter something) (enter something) "next", etc?
Also add some temporary princ statements of variables inside the PROGN, example (princ "\nnestlevel")(princ nextlevel), and see if the values match what is needed for prompts? Or - in Acad, use IDE to walk through each line step by step and use watch window to check variables
hmspe
« Reply #6 on: August 24, 2016, 06:41:09 PM »
Could you post a block that this is supposed to work with?
The "*Invalid selection*  Expects a single object." message makes this look like there is an issue with entity selection.
ctrlaltdel
« Reply #7 on: August 24, 2016, 08:31:40 PM »
At the start of the command, after clicking an entity, its should go straight to Block IN-Place/refedit mode of a block level. But the last edited LISP I did, did not do that but instead it immediately proceed to this command
Select reference:
which leads to a usual refedit command which is not I wanted.
ctrlaltdel
« Reply #8 on: August 24, 2016, 08:54:50 PM »
Hi hmspe. You can refer to the link below where i posted a block.
https://www.theswamp.org/index.php?topic=51887.0
ur_naz
  • Made in Ukraine
« Reply #9 on: September 11, 2016, 09:46:53 PM »
AutoCAD can't select outside visible drawing area, Bricscad can. That's a difference... It can't be fixed. You must zoom out to select all you need in AutoCAD.
ctrlaltdel
« Reply #10 on: September 12, 2016, 12:53:54 AM »
Hi ur_naz. The issue has been resolve in my other thread.
