Is there a way to get through the prompts for hit any key?
I was trying the Expert variable but the only references I have are:
;EXPERT - Controls whether certain prompts are issued.
;0 Issues all prompts normally.
;1 Suppresses "About to regen, proceed?" and "Really want to turn the current layer off?"
;2 Suppresses the preceding prompts and "Block already defined. Redefine it?"
; (BLOCK) and "A drawing with this name already exists. Overwrite it?" (SAVE or WBLOCK).
;3 Suppresses the preceding prompts and those issued by the LINETYPE command if you try to load a linetype
; that’s already loaded or create a new linetype in a file that already defines that linetype.
;4 Suppresses the preceding prompts and those issued by UCS Save and VPORTS Save if the name you supply already exists.
;5 Suppresses the prompt, "That name is already in Use, redefine it?"
; issued by the -DIMSTYLE Save option when you supply the name of an existing dimension style.
Any feedback appreciated. VARS2SCR isn't really what I was looking for.
