All of the example code that I have found online do not acknowledge that calling a function in an object initializer is possible.
The part of the previous post that I was trying to call attention to was this part which is in the "Object Initializer" portion of the PaletteSet(string name) constructor.Code - C#: [Select]
{ "Circle Radius", }
Hi MickD,
I failed to fully describe what I was talking about plus I had a function named "Initialize", so I'm sorry for the confusion.
Here is a link to C# feature that I am talking about:
How to: Initialize Objects by Using an Object Initializer (C# Programming Guide)https://msdn.microsoft.com/en-us/library/bb397680.aspx (https://msdn.microsoft.com/en-us/library/bb397680.aspx)
In some of their examples they are using the compiler created default constructor to create a new Student with and "Object Initializer" to establish the properties of that student.Code - C#: [Select]
Each property is named and there is no mention in this web page of calling a function named or unnamed inside of the "Object Initializer".
The intended function is not named but it appears from ILSPY that the compiler is using the variable types to choose this function:Code - C#: [Select]
public Palette Add(string name, Control control);
