This is what I had in mind.
;; CAB @ TheSwamp.org 06/05/2008
(Defun C:SQR (/ SquareWidth RoundWidth Run ptBase ll lr ur ul um acDoc obj1 obj2
err lyrobj LayerName
;; CAB 05/31/07
(defun activespace (doc)
(if (or (= acmodelspace (vla-get-activespace doc))
(= :vlax-true (vla-get-mspace doc))
(vla-get-modelspace doc)
(vla-get-paperspace doc)
(defun MakePline (space point-list)
(vlax-invoke space
'AddLightWeightPolyline
(apply 'append point-list) ; 2D point list
;; returns nil if make failed
(defun MakeLayer (lyrname acDoc / lyrobj)
(not
(vl-catch-all-error-p
(setq lyrobj
(vl-catch-all-apply
'vla-add
(list (vla-get-layers acDoc) lyrname))
lyrobj
(setq acDoc (vla-get-activedocument (vlax-get-acad-object)))
;; Create the layer
(if (setq lyrobj (MakeLayer "Equip" acDoc))
(vla-put-color lyrobj "123")
(vlax-release-object lyrobj)
(setq LayerName "Equip")
(and
(setq SquareWidth (getdist "\nEnter the Square Width: "))
(setq RoundWidth (getdist "\nEnter the Round Width: "))
(setq Run (getdist "\nEnter the lenght: "))
;; draw the object at 0,0 as the base point at middle of
;; the square end, then move to desired location.
(setvar "plinewid" 0)
(setq ptBase '(0 0)
ll (polar ptBase pi (/ SquareWidth 2.))
lr (polar ptBase 0.0 (/ SquareWidth 2.))
um (polar ptBase (/ pi 2) Run)
ul (polar um pi (/ RoundWidth 2.))
ur (polar um 0.0 (/ RoundWidth 2.))
(if (setq obj1 (MakePline (activespace acDoc) (list ll lr ur ul)))
(vla-put-Closed Obj1 :vlax-true)
(and LayerName (vla-put-Layer Obj1 LayerName))
;;(vla-put-Closed PolObj :vlax-true)
;;(vla-put-Color PolObj AcYellow)
;;(vla-put-Linetype PolObj "HIDDEN")
(if (setq obj2 (MakePline (activespace acDoc) (list ll um lr)))
(and LayerName (vla-put-Layer Obj2 LayerName))
(vla-put-Color Obj2 AcWhite)
(setq err (vl-catch-all-apply
'vl-cmdf
(list "_.move"
(vlax-vla-object->ename obj1)
(vlax-vla-object->ename obj2)
"" "_non" ptBase pause))
(if (< (distance ptBase (getvar "lastpoint")) 0.000001)
;; objects were not moved, so erase them
(and obj1 (vla-erase obj1))
(and obj2 (vla-erase obj2))
