Author Topic: Mleader "ExtendLeaderToText" variable  (Read 2355 times)
T-Square
« on: April 29, 2014, 03:33:57 PM »
Hello All,
I found a routine to create an MLeader Style and set "most" all of it's variables. It does all I need except the "ExtendLeaderToText" is set to "on", I don't want the leader to extend to text. How does one go about modifying this to be "off"?
I have included a dump of the VLA and the routine I use. I am calling the routine from within my all encompassing lisp file that has all of the routines I use, wherever I go. Thus the (defun yaddayaddayadda (/)
I also use the much appreciated and awesomeness that is Lee Macs code for left justifying the text of the mleader. Thanks to Lee Mac.
Thanks in advance. :-)
(defun c:ML (/)
(INITERR)
(command ".undo" "end")
(command ".undo" "m")
(GETSPACE)
(MAKETXTSTYLE)
(MAKETXTLAYER)
(make_mleader_style "ARCH" 256 256);Mleader style name "ARCH" colors set to bylayer
(setvar "CMLEADERSTYLE" "ARCH")
(setvar "MLEADERSCALE" DIMSC)
(initcommandversion)
(command ".mleader")
(while (= (logand (getvar "CMDACTIVE") 1) 1)
(command pause)
(RESET)
(defun MAKETXTSTYLE (/)
(setvar "CMDECHO" 0)
(if (not (tblsearch "style" "Simplex"))
(command ".-style" "SIMPLEX" "simplex.shx" "0.00000000" "0.90000000" "0.00000000" "N" "N" "N")
(princ "\nText Style \"Simplex\" Already Exists... Text Style Un-Changed... ")
(setvar "textstyle" "Simplex")
(defun GETSPACE (/)
(if (and (equal (getvar "TILEMODE") 0)
(equal (getvar "CVPORT") 1)
(setq CSPACE 1);paper space
(setq CSPACE 0);model space.
(if (= CSPACE 1)
(setq DIMSC 1.0)
(setq DIMSC(getvar "DIMSCALE"))
(defun MAKETXTLAYER (/)
(setq DISL "TEXT")
(if (not (tblsearch "layer" DISL))
(command ".-layer" "thaw" DISL "on" DISL "unlock" DISL "make" DISL "color" "4" DISL "lt" "continuous" DISL "")
(princ (strcat "\nLayer " DISL " Already Exists... Layer Un-Changed... "))
(setvar "clayer" DISL)
Code:
;;;original code by VV
(defun make_mleader_style (mleaderstylename textcolor leadercolor / adoc mldrdict newldrstyle objcolor)
  (setq adoc (vla-get-activedocument (vlax-get-acad-object)))
  (setq mldrdict (vla-item (vla-get-dictionaries adoc) "ACAD_MLEADERSTYLE"))
  (setq newldrstyle (vlax-invoke mldrdict 'addobject mleaderstylename "AcDbMLeaderStyle"))
  (setq objcolor (vla-getinterfaceobject (vlax-get-acad-object) (strcat "AutoCAD.AcCmColor."(substr (getvar "acadver") 1 2))))
  (vla-put-colorindex objcolor textcolor)
  (vla-put-textcolor newldrstyle objcolor)
  (vla-put-colorindex objcolor leadercolor)
  (vla-put-leaderlinecolor newldrstyle objcolor)
  (foreach item
   (list
     '("AlignSpace" 4)
     '("BitFlags" 0)
'("ArrowSize" 0.1250);Arrowhead Size
     '("BlockConnectionType" 1)
     '("BlockRotation" 0.0)
     '("BlockScale" 1.0)
     '("BreakSize" 0.06250);Break Size
     '("ContentType" 2);Multileader Type, Mtext
     '("Description" "Arch")
     '("DoglegLength" 0.1250);Landing Distance
     '("DrawLeaderOrderType" 0)
     '("DrawMLeaderOrderType" 1)
     '("EnableBlockRotation" -1)
     '("EnableBlockScale" -1)
     '("EnableDogleg" -1)
     '("EnableFrameText" 0)
     '("EnableLanding" -1)
'("ExtendLeaderToText" -1)
     '("FirstSegmentAngleConstraint" 0)
     '("LandingGap" 0.06250)
     '("LeaderLineType" 1);Bylayer
     '("LeaderLineTypeId" "ByLayer")
     '("LeaderLineWeight" -1);Bylayer
     '("MaxLeaderSegmentsPoints" 2)
     '("ScaleFactor" 1.0)
     '("SecondSegmentAngleConstraint" 0)
     '("TextAlignmentType" 0)
     '("TextAngleType" 1);Keep horizontal
     '("TextHeight" 0.1250);Text Height
     '("TextLeftAttachmentType" 1);Middle of Top Line
     '("TextRightAttachmentType" 1);Middle of Top Line
     '("TextString" "")
     '("TextStyle" "SIMPLEX")
);_ end of list
    (vlax-put newldrstyle (car item) (cadr item))
) ;_ end of foreach
  newldrstyle
(MLSLEFT)
) ;_ end of defun
;;; The following code is from Lee Mac to resolve the issue with "Always Left Justify Mleader Text"
(defun MLSLEFT ( / dic itm )
    (if (setq dic (cdr (assoc -1 (dictsearch (namedobjdict) "ACAD_MLEADERSTYLE"))))
        (while (setq itm (dictnext dic (null itm)))
            (entmod (subst '(297 . 1) (assoc 297 itm) itm))
MultiLeader Dump
Select object: ; IAcadMLeader2: AutoCAD Multi-Leader Interface
; Property values:
;   Application (RO) = #<VLA-OBJECT IAcadApplication 0000000140d0a1d8>
;   ArrowheadBlock = ""
;   ArrowheadSize = 0.125
;   ArrowheadType = 0
;   BlockConnectionType = 1
;   BlockScale = 1.0
;   ContentBlockName = ""
;   ContentBlockType = 6
;   ContentType = 2
;   Document (RO) = #<VLA-OBJECT IAcadDocument 000000003cb3a770>
;   DogLegged = -1
;   DoglegLength = 0.125
;   EntityTransparency = "ByLayer"
;   Handle (RO) = "2E2"
;   HasExtensionDictionary (RO) = 0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 0000000031515f98>
;   LandingGap = 0.0625
;   Layer = "MT"
;   LeaderCount (RO) = 1
;   LeaderLineColor = #<VLA-OBJECT IAcadAcCmColor 0000000031515390>
;   LeaderLinetype = "ByLayer"
;   LeaderLineWeight = -1
;   LeaderType = 1
;   Linetype = "ByLayer"
;   LinetypeScale = 1.0
;   Lineweight = -1
;   Material = "ByLayer"
;   ObjectID (RO) = 44
;   ObjectID32 (RO) = 44
;   ObjectName (RO) = "AcDbMLeader"
;   OwnerID (RO) = 43
;   OwnerID32 (RO) = 43
;   PlotStyleName = "ByLayer"
;   ScaleFactor = 1.0
;   StyleName = "ARCH"
;   TextAttachmentDirection = 0
;   TextBackgroundFill = 0
;   TextBottomAttachmentType = 0
;   TextDirection = 5
;   TextFrameDisplay = 0
;   TextHeight = 0.125
;   TextJustify = 1
;   TextLeftAttachmentType = 1
;   TextLineSpacingDistance = 0.208333
;   TextLineSpacingFactor = 1.0
;   TextLineSpacingStyle = 1
;   TextRightAttachmentType = 1
;   TextRotation = 0.0
;   TextString = "ASDFADSF\\PADSFASDF\\PADSFADFAADSFASDF"
;   TextStyleName = "SIMPLEX"
;   TextTopAttachmentType = 0
;   TextWidth = 0.0
;   TrueColor = #<VLA-OBJECT IAcadAcCm
Select object:
Color 0000000031514850>
;   Visible = -1
roy_043
  • BricsCAD 18
Re: Mleader "ExtendLeaderToText" variable
« Reply #1 on: April 30, 2014, 03:15:06 AM »
This works on BricsCAD:
(setq elist (entget (vlax-vla-object->ename newldrstyle)))
(entmod ; Note: Partial elist with only gc -1 and 298 does not work.
  (subst
    '(298 . 1)
    (assoc 298 elist)
    elist
