Author Topic: Insert Blocks and INSUNITS  (Read 5230 times)
Bennos
  • Mosquito
« on: May 01, 2007, 08:03:21 PM »
Hello,
I'm currently in the process of creating a class for BlockTableRecords, with in this class i have created an Insert function. Inserting blocks with known scales is not a problem, but i was after was some more information regarding to how autocad deals with the INSUNITS system variable. As when you do a manual insert, it rescales the block to suit the current INSUNITS variable. How is this conversion done, and how would i go about replicating it.
Thanks in advance
Bennos
Re: Insert Blocks and INSUNITS
« Reply #1 on: May 01, 2007, 08:49:38 PM »
You may also want to have a look at the system variables INSUNITSDEFSOURCE and INSUNITSDEFTARGET
Bennos
  • Mosquito
« Reply #2 on: May 01, 2007, 09:20:50 PM »
Thanks Kerry, will check it out.
Found the problem, you need to set the blocktablerecords units value after you add it to the block table.
« Last Edit: May 01, 2007, 09:38:55 PM by Bennos »
« Reply #3 on: May 01, 2007, 09:38:47 PM »
I've just had a scan of the Managed Class docs
Autodesk.AutoCAD.DatabaseServices.BlockTableRecord Properties
has a Property .Units
You may be able to make use of this.
Bennos
  • Mosquito
« Reply #4 on: May 01, 2007, 10:20:03 PM »
Thanks for the tip, i have the blocktablerecord units property to the insunits form the source database.
Have another problem, how does autocad determine the scale between millimeters and meters, ie 0.001 and feet to millimeters i.e 304.8.
I need to scale my blockreference to these scales for them to insert at the scaled size.
« Reply #5 on: May 01, 2007, 10:35:22 PM »
If I understand the question ...
Some of the more common INSUNITS <UnitsValue Field> settings include:
0 = Unspecified (No units)
1 = Inches
2 = Feet
4 = Millimeters
6 = Meters
Would you just factor according to the setting ?
Source 4 to Target 6  is * 0.001
6 to 4 is * 1000
4 to 1 is * 0.0393700787402...
.. etc
( OR the other way around :-))
« Last Edit: May 01, 2007, 11:07:52 PM by Kerry Brown »
Bennos
  • Mosquito
« Reply #6 on: May 01, 2007, 11:25:04 PM »
1 = Inches
2 = Feet
4 = Millimeters
6 = Meters
6 to 4 is * 1000
.. etc
Good point, will probably go with your option. Thanks for your help.
Bennos
  • Mosquito
« Reply #7 on: May 02, 2007, 01:16:26 AM »
1 = Inches
2 = Feet
4 = Millimeters
6 = Meters
6 to 4 is * 1000
.. etc
Found the DatabaseServices.UnitConverter.GetConversionFactor
This does the convertion for all the unit types.
« Reply #8 on: May 02, 2007, 01:57:37 AM »
Good find , that's comforting to hear, I think.  ... persistance IS rewarded. !!
