Author Topic: dumb question from the untrained.....  (Read 2234 times)
CottageCGirl
« on: September 24, 2015, 02:45:36 PM »
Help.. have cut this dwg to only a few layers.. but when I bring in my office furn block.. it shows all the x grips HUGE and I cant see what I am doing.. what setting do I change to make it viewable.. its driving me crazy...
yes.. another chunk of time wasted on a problem I could have solved on my own with just a little training.. #bosswontlisten
any helpful guidance would be appreciated
CCG.
Matt__W
  • I like my water diluted.
Re: dumb question from the untrained.....
« Reply #1 on: September 24, 2015, 02:49:10 PM »
DDPTYPE?? Change the points to a .
Autodesk Expert Elite
« Reply #2 on: September 24, 2015, 02:49:53 PM »
Set PDMODE to 0
Yikes that's a dirty drawing: 94809 registered applications deleted.
Matt__W
« Reply #3 on: September 24, 2015, 02:51:10 PM »
Or, if you need to see the X's (but at a smaller size) change the absolute size or relative size percentage.
Matt__W
« Reply #4 on: September 24, 2015, 02:51:48 PM »
*cough* *cough* You wouldn't have this problem if you were using Revit *cough* *cough*  ;)
CottageCGirl
« Reply #5 on: September 24, 2015, 02:54:41 PM »
not my call...
CottageCGirl
« Reply #6 on: September 24, 2015, 02:55:16 PM »
Set PDMODE to 0
and for the win!!!!!  yay.... knew it was something easy... thanks sooo much..
*virtual 6 pack*
