Author Topic: Problem with hatch angle of MPolygon  (Read 1849 times)
Bernd
« on: June 12, 2017, 05:03:52 AM »
I have difficulties getting the hatch angle of e.g. ANSI31 drawn correctly. I want to align the pattern to the longest side of the MPolygon.
Therefore I use the following code:
                    mPolygon.SetPattern(HatchPatternType.PreDefined, muster);
                    mPolygon.Color = umringFarbe;
                    mPolygon.PatternColor = fuellFarbe;
                    mPolygon.Layer = layer;
                    if (muster.ToUpperInvariant() != "SOLID")
                        double winkel = schraffurWinkel + laengsteLinie.Direction.Angle;
                        if (winkel > 2 * Math.PI)
                            winkel -= Math.PI;
                        if (winkel >= 0 && winkel < Math.PI)
                            mPolygon.PatternAngle = winkel;
                        else
                            mPolygon.PatternAngle = winkel - Math.PI;
                        mPolygon.PatternScale = schraffurFaktor == 0 ? 1 : schraffurFaktor;
muster is the name of the pattern - in this case ANSI31 - , laengsteLinie the longest side of the MPolygon.
Later on the MPolygon is added like this:
                    try
                        ObjectId blockTableId = dwg.BlockTableId;
                        var bt = (BlockTable)trans.GetObject(blockTableId, OpenMode.ForRead);
                        ObjectId modelSpace = bt[BlockTableRecord.ModelSpace];
                        var btr = (BlockTableRecord)trans.GetObject(modelSpace, OpenMode.ForWrite);
                        btr.AppendEntity(mPolygon);
                        handle = mPolygon.Handle.Value;
                        mPolygon.RecordGraphicsModified(true);
                        trans.AddNewlyCreatedDBObject(mPolygon, true);
                        trans.Commit();
                        return handle;
Everything works as expected except the hatch angle. The hatch is being drawn in a 45° angle, which is how the hatch is defined, no mattern how the surrounding rectangle (or whatever the shape is) is rotated. Looking at the MPolygon's properties I see, that there is actually a different angle defined, the one that I programatically defined. And as soon as I change some other property, e.g. the spacing, the MPoylgon is being redrawn, this time with the angle applied. How come?
Any ideas are highly appreciated...
Thanks, Bernd
Bryco
Re: Problem with hatch angle of MPolygon
« Reply #1 on: June 13, 2017, 07:46:36 PM »
I do something similar but in 2 steps.
Second step:
                    Hatch h = tr.GetObject(id, OpenMode.ForWrite) as Hatch;
                    h.PatternAngle = ang;
                    h.PatternScale = scale;
                    h.SetHatchPattern(HatchPatternType.PreDefined, sHatch);
                    tr.Commit();
I wonder if .SetHatchPattern must be after setting the angle
Bernd
« Reply #2 on: June 14, 2017, 06:12:01 AM »
Bingo!
Looks like MPolygon.SetPattern() has to be the last call after the hatch's other properties have been set.
Thanks a lot for that hint!
