Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
AutoLISP (Vanilla / Visual)
Topic:
Emacs indentation
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Emacs indentation (Read 1295 times)
JohnSnow
Newt
Emacs indentation
on:
September 10, 2018, 07:06:38 PM »
Hi Guys.
Just wondering if anyone uses Emacs that can help me with the indentation.
The Indentation I want is as below.
(defun c:test()
(...) ;tab when a new structure starts
);in line with function defun
Logged
Administrator
Seagull
Re: Emacs indentation
Reply #1 on:
September 11, 2018, 07:51:27 AM »
From here:
http://ergoemacs.org/emacs/emacs_tabs_space_indentation_setup.html
Looks as though there is no way to always use TAB but you can use a workaround.
Code - Lisp:
[Select]
defun
my-insert-tab-char
"Insert a tab char. (ASCII 9,
\t
interactive
insert
\t
global-set-key
kbd
"TAB"
'my-insert-tab-char
; same as Ctrl+i
BTW, why TAB?
Logged
TheSwamp.org
(serving the CAD community since 2003)
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
Topic:
Emacs indentation
