Author Topic: Need fresh eyes to check this lisp  (Read 1454 times)
HasanCAD
« on: April 15, 2014, 07:42:18 AM »
Could a fresh eyes check this subroutine why stop working in this part
  (command "MASSPROP" obj "" "Y" wPath)
(defun C:CEN ( / doc index obj objects objlay objlist objtype )
  (setq doc (vla-get-activedocument (vlax-get-acad-object)))
  (LM:startundo doc)
  ;(setq obj (getpoint "Pick inside closed area"))
  (setq objects (ssget '((-4 . "<OR")(0 . "LWPOLYLINE")(0 . "REGION")(-4 . "OR>")))
obj (ssname objects 0))
  (while obj
    (setq objlist (entget obj))
    (setq objtype (cdr (assoc 0 objlist)))
    (setq objlay  (cdr (assoc 8 objlist)))
     ((and (= objtype "LWPOLYLINE") (= (cdr (assoc 70 objlist)) 1)) (command "REGION" obj "") (setq obj (entlast)) (get_centroid_point))
     ((= objtype "REGION") (get_centroid_point)))
    (setq index (+ index 1)
            obj (ssname objects index))
    (LM:endundo doc)
    (princ "\n       q_|_|| _\\|| q_|| _\\|      ")
  (princ "\n  Type  CEN  to invoke the lisp")
(defun get_centroid_point (/ wpath open-a data vlen X-value Y-value c-point objtype ss )
  (setq fd (getvar "filedia")) (setvar "FILEDIA" 0)
  (setq cd (getvar "CMDECHO")) (setvar "CMDECHO" 0)
  (command "LAYER" "set" objlay "")
  (setq wPath nil)
  (if (setq wPath (findfile "ACAD.PAT"))
        (setq wPath (vl-filename-directory wPath))
(or (eq "\\" (substr wPath (strlen wPath)))
    (setq wPath (strcat wPath "\\data")))))
  (setq datafile (strcat wPath ".mpr"))
  (setq open-a (open datafile) "r")
  (setq data "" )
  (while (not (wcmatch data "Centroid:*"))
    (setq data (read-line open-a))
  (setq    vlen (- (strlen data) 26)
        X-value (atof (substr data 26 vlen))
        Y-value (atof (substr (read-line open-a) 26 vlen))
        c-point (list X-value Y-value)
  (close open-a)
  (if (= objtype "LWPOLYLINE")
      (command "EXPLODE" obj)
      (setq  ss (ssget "p")
            obj (ssname ss 0))
      (command "PEDIT" obj "Y" "Join" ss "" "")
  (command "POINT" c-point)
  (setvar "FILEDIA" fd)
  (setvar "CMDECHO" cd)
;Error
  (defun *error* ( msg )
        (if val (mapcar 'setvar var val))
        (if doc (LM:endundo doc))
        (if (not (wcmatch (strcase msg) "*BREAK,*CANCEL*,*EXIT*"))
            (princ (strcat "\nError: " msg))) (princ))
  (defun LM:startundo ( doc ) (LM:endundo doc) (vla-startundomark doc))
  (defun LM:endundo ( doc ) (while (= 8 (logand 8 (getvar 'undoctl))) (vla-endundomark doc)))
ribarm
  • Marko Ribar, architect
Re: Need fresh eyes to check this lisp
« Reply #1 on: April 15, 2014, 08:00:35 AM »
Why don't you use this method for obtaining Centroid data after you convert LWPOLYLINE to REGION...
(defun c:centroid ( / ss ent enta )
  (setq ss (ssget "_+.:E:S" '((0 . "3DSOLID,REGION"))))
  (setq ent (ssname ss 0))
  (setq enta (vlax-ename->vla-object ent))
  (setq cent (vlax-safearray->list (vlax-variant-value (vla-get-centroid enta))))
  (prompt "\nCentroid : ") (princ cent)
  (prompt "\nVariable is called \"cent\" - you call it with !cent")
M.R.
M.R. on Youtube
