Author Topic: Pressure pipes and fittings  (Read 4697 times)
ChrisCarlson
Re: Pressure pipes and fittings
« Reply #15 on: August 11, 2016, 02:49:42 PM »
Why not set incremental angle to 90° and add 11°, 22° and 45° as additional angles?
//Also this isn't really an AutoLISP question as it is a CAD General...
Fabricio28
« Reply #16 on: August 11, 2016, 03:36:22 PM »
Hi Master Shake
I've already incremented these angles and isn't working as I wish.
I'd like to draw 11°, 22°, 45° and 90°...
But I want draw this angles all over 360° .
Maybe it is not a CAD General question, I think.
because Polar Tracking isn't working as I want to.
Besides I don't know how to explain better my task.  :embarrassed2:
« Last Edit: August 11, 2016, 03:45:40 PM by FABRICIO28 »
ChrisCarlson
« Reply #17 on: August 11, 2016, 04:02:42 PM »
Enabling relative to last segment works as expected.
ChrisCarlson
« Reply #18 on: August 11, 2016, 04:05:50 PM »
proof of concept attached.
You might want to also add the following angles -> 349, 328, 315. This will allow you to go both directions from the last point.
« Last Edit: August 11, 2016, 04:09:29 PM by Master_Shake »
Fabricio28
« Reply #19 on: August 12, 2016, 07:11:54 AM »
Thank you very much!!
Worked perfect "go to both directions" that is the word!!.  :oops:
I've tested and worked perfect to me, you're completly right @Master_Shake my doubts is Autocad Gerenal, sorry for that.
Just that 3 angles (349, 328, 315) I'm able to draw the polyline all directions that I want?
Fantastic!
ChrisCarlson
« Reply #20 on: August 12, 2016, 08:06:38 AM »
Set your increment angle to 90° and add the 6 additional angles.
11, 22, 45, 315, 328, 349.
Granted 180 and 270 will be options but unless you want to go a lisp routine I don't think you can set additional angles without incremental angles.
Fabricio28
« Reply #21 on: August 12, 2016, 08:48:20 AM »
Thank you for the support Master_Shake. :)
« Reply #22 on: August 12, 2016, 09:01:06 AM »
In my little world of fittings, 11.25 is the only angle you need .. not sure why you need more angles to go 'both' directions?
Glad you got it sorted though.  :)
ChrisCarlson
« Reply #23 on: August 12, 2016, 09:21:17 AM »
When relative to UCS is enabled, the last two points determine 0°. If 11/22/45 are your only options, the poly line will only go counter clockwise.
« Reply #24 on: August 12, 2016, 09:51:03 AM »
Isn't that why we're using relative to last segment? .. Either way what you told him seems to solve the problem .. I just do it differently :)
Fabricio28
« Reply #25 on: August 12, 2016, 02:35:07 PM »
Thank you ron,
You helped me a lot too.
