Author Topic: How do I override a dimension?  (Read 2515 times)
dubb
« on: March 09, 2017, 05:20:21 PM »
I am trying to suppress or turn off a dimension extension line.
These are the dimstyles but I cannot find the entity. I hope I have the terminology correct. Or perhaps I don't know how to override a dimension correctly.
dxf 75 dimse1
dxf 76 dimse2
My basic script
(setq en (car(entsel)))
(setq ed (entget en))
(setq ed (subst (cons 75 1) (assoc 75 ed) ed))
(entmod ed)
BKT
Re: How do I override a dimension?
« Reply #1 on: March 10, 2017, 10:36:29 AM »
dubb
« Reply #2 on: March 10, 2017, 11:40:48 AM »
That works, however I was wondering if we can accomplish it with entmod.
« Reply #3 on: March 10, 2017, 12:35:36 PM »
An example:
  1. (defun c:dimextsuppress ( / a i s x )
  2.     (initget "First Second Both")
  3.     (setq a (cond ((getkword "\nExtension line to suppress [First/Second/Both] <Both>: ")) ("Both")))
  4.     (if (setq s (ssget "_:L" '((0 . "*DIMENSION"))))
  5.         (progn
  6.             (regapp "ACAD")
  7.             (setq x
  8.                 (list
  9.                     (list -3
  10.                         (append
  11.                            '("ACAD" (1000 . "DSTYLE") (1002 . "{"))
  12.                             (if (member a '("First"  "Both")) '((1070 . 75) (1070 . 1)))
  13.                             (if (member a '("Second" "Both")) '((1070 . 76) (1070 . 1)))
  14.                            '((1002 . "}"))
  15.                         )
  16.                     )
  17.                 )
  18.             )
  19.             (repeat (setq i (sslength s))
  20.                 (entmod (append (entget (ssname s (setq i (1- i)))) x))
  21.             )
  22.         )
  23.     )
  24.     (princ)
  25. )
Note that this example will remove any existing overrides.
« Reply #4 on: March 10, 2017, 12:41:44 PM »
Pre-empting your next question, here is a (potentially incomplete) reference for the dimension style override codes.
lamarn
« Reply #5 on: March 12, 2017, 06:29:53 PM »
Dear mr. Lee Mac. Amazing efficient stuff.
Could you point out what part is the 'make it 0' that makes DIMSE1 and DIMSE1 turn off.
Could use it to toggle. Kind regards Hans
@Dubb
Here is one of mine about the same thing..
Maybe helps a bit
https://www.theswamp.org/index.php?topic=51581.msg566568#msg566568
« Last Edit: March 12, 2017, 06:33:34 PM by lamarn »
Design is something you should do with both hands. My 2d hand , my 3d hand ..
dubb
« Reply #6 on: March 13, 2017, 11:23:29 AM »
Beautiful! Thanks Lee & lmarn.
« Reply #7 on: March 13, 2017, 02:36:01 PM »
Thank you  :-)
Note that the sample program above is applying a dimension style override only to the selected dimensions and not an override to the active dimension style itself, therefore the program will not affect the values of the DIMSE1 & DIMSE2 system variables.
A toggle of this nature is possible but far more complex to implement, as the program would need to retrieve the dimension style override xdata, parse the xdata into pairs of system variable codes and associated values, test for the presence of 75 & 76 and toggle the associated values if present; however, if the codes corresponding to these system variables are not present, the program would also need to check whether the dimension style is already suppressing either extension line in order to determine the appropriate value to be added as a dimension style override (e.g. the dimension style may already be suppressing the first extension line, therefore to achieve a true toggle, the program would need to override this suppression).
lamarn
« Reply #8 on: March 13, 2017, 04:13:58 PM »
This 'ON' options works fine for me ..   :whistling:
    (initget "First Second Both ON")
    (setq a (cond ((getkword "\nExtension line to suppress [First/Second/Both or ON] <Both>: ")) ("Both")))
            (regapp "ACAD")
            (setq x
                (list
                    (list -3
                        (append
                            (if (member a '("ON")) '((1070 . 76) (1070 . 0)))
                           '((1002 . "}"))
« Reply #9 on: March 13, 2017, 06:35:32 PM »
I thought you wanted to toggle the current state?  :?
lamarn
« Reply #10 on: March 14, 2017, 02:06:49 AM »
Sorry, i didn't explain myself good nough. Just a option to turn ON/OFF is what i meant with toggle..
« Last Edit: March 14, 2017, 02:42:24 AM by lamarn »
dubb
« Reply #11 on: March 15, 2017, 03:36:28 PM »
Thanks for this explanation. Apparently I am clueless when it comes to xdata. Will need to add that to my "To Learn" list.
