Author Topic: Toggle Variables?  (Read 4651 times)
VerticalMojo
Toggle Variables?
« on: January 28, 2005, 04:02:36 PM »
Using a macro, is there a way to toggle a variable?
Example: Gripblock: toggle between 0 and 1
*Edit* I ment 0 - 1 not 1 - 2  :roll:
Zydenet
Toggle Variables?
« Reply #1 on: January 28, 2005, 04:40:10 PM »
Do you mean between 0 and 1?
Try this for a button
(setvar "GRIPBLOCK" (- 1 (getvar "GRIPBLOCK")))
or for a command line version
(defun c:GB ()
Toggle Variables?
« Reply #2 on: January 28, 2005, 04:58:23 PM »
Like this?
Command: (setvar "GRIPBLOCK" (boole 6 (getvar "GRIPBLOCK") 1))
1
0
* Edit:
Sorry, i should prolly use the Var. you wanted to use in my example. I fixed my example to use the variable you used in your question.)
VerticalMojo
Toggle Variables?
« Reply #3 on: January 28, 2005, 04:59:52 PM »
Yeah thats what I ment, 0-1.
I need it done without the use of LISP. Most computers here have AutoCAD LT.
I wish everbody had it, it would make my life a lot easier! Maybe soon. :roll:
Toggle Variables?
« Reply #4 on: January 28, 2005, 05:03:21 PM »
huh?! Does LT support Diesel? (I hope diesel has a "boole" function. :D Im gonna go look.)
VerticalMojo
Toggle Variables?
« Reply #5 on: January 28, 2005, 05:19:19 PM »
Quote from: Se7en
It does support Diesel.....
Toggle Variables?
« Reply #6 on: January 28, 2005, 05:27:55 PM »
Have you ever read this document?
http://www.crlf.de/Dokumente/Diesel/Diesel.html
Dommy2Hotty
Toggle Variables?
« Reply #7 on: January 28, 2005, 05:30:14 PM »
Not relevent to you, but just to show:
(if (=(getvar "osnaphatch")0)(setvar "osnaphatch" 1)(setvar "osnaphatch" 0))
Toggle Variables?
« Reply #8 on: January 28, 2005, 05:33:39 PM »
Hey Dommy, Re-read my first post. (using Boole is a much cleaner way to do what your doing in that statement.)
VerticalMojo
Toggle Variables?
« Reply #9 on: January 28, 2005, 05:34:49 PM »
Quote from: Se7en
Yeah, its been awhile and I really didn’t figure out how to do it well. How would I execute the Diesel command you gave me?
Toggle Variables?
« Reply #10 on: January 28, 2005, 05:38:44 PM »
I didnt give you a diesel command. But if you read that page cloesly, youll get lead to this page with gives you the syntax of each diesel command.
http://www.fourmilab.ch/diesel/
Follow the links on that page and you can get some really cool ideas. He even gives examples so im sure you can figure out how to toggle the variable.
VerticalMojo
Toggle Variables?
« Reply #11 on: January 28, 2005, 05:53:37 PM »
Quote from: Se7en
That’s what I thought, but I wasn’t sure since you probably know more about it than I do! Thanks for the links though!  :) I will check them out this weekend.
By the way, you guys have a good weekend! see ya on monday!
Dommy2Hotty
Toggle Variables?
« Reply #12 on: January 29, 2005, 09:13:56 AM »
Thanks Se7en, I'll look into that.  Gotta get more advanced sometime :twisted:
VerticalMojo
Toggle Variables?
« Reply #13 on: February 04, 2005, 05:54:34 PM »
^C^Cgripblock $M=$(-,1,$(getvar,gripblock))
thanks 7....
Zydenet
Toggle Variables?
« Reply #14 on: February 04, 2005, 08:38:53 PM »
I'm sorry. I didn't realize you didn't have one yet. All you needed to do was add ^C^C in front of (setvar "GRIPBLOCK" (- 1 (getvar "GRIPBLOCK"))) in my first post.
^C^C(setvar "GRIPBLOCK" (- 1 (getvar "GRIPBLOCK")))
