Author Topic: Polyline drawn with multiple vertices from two pick points?  (Read 5329 times)
demesne
« on: February 02, 2012, 10:58:00 AM »
Hi
I've been told I may be able to find what I'm looking for over here.
Does anyone have a routine (I've searched but can't find) to draw a straight polyline with a vertex every metre (or other specified distance). Also useful would be the option to 'equal segment lengths'.
So, if a polyline was drawn by picking two points, start and end, and the line had a length of, say, 7.2m then there would be the option to add a vertex every metre, leaving the last segment length at 0.2m, or, each segment length would be the same - 7 segments at 1.028571428571429m (I didn't work that out in my head!).
I see that if the user picks more than two initial points then the routine would have to treat each initial segment individually. Would also be useful if it worked with arcs.
Like I said, I have looked but couldn't find anything.
Oh, btw, I'm fitting polylines to point cloud data using 3rd party software.
Regards
Demesne
Re: Polyline drawn with multiple vertices from two pick points?
« Reply #1 on: February 02, 2012, 11:35:28 AM »
Welcome to the Swamp.
There are many lisp that almost do what you want but not exactly.
Most deal with an existing pline and would need to be modified.
demesne
« Reply #2 on: February 02, 2012, 11:52:15 AM »
Thanks.  I don't suppose you know where I'd find them do you.  I have searched, but to no avail.
« Reply #3 on: February 02, 2012, 01:33:01 PM »
I'll look when I get back but here is a quickie, no testing.
  1. (defun c:pldivide (/ ps pe sl tl ang di pts)
  2.
  3.   (defun makepline (pt_lst lay clsd) ; clsd must be 1 or 0
  4.     (entmakex
  5.       (append
  6.         (list '(0 . "LWPOLYLINE")
  7.               '(100 . "AcDbEntity")
  8.               '(100 . "AcDbPolyline")
  9.               (cons 8 "0")
  10.               (cons 90 (length pt_lst))
  11.               (cons 70 clsd) ; 1 for closed 0 overwise
  12.         )
  13.         (mapcar '(lambda (pt) (cons 10 pt)) pt_lst)
  14.       )
  15.     )
  16.   )
  17.
  18.   (if (and (setq ps (getpoint "\nPick Start point."))
  19.            (setq pe (getpoint ps "\nPick End point."))
  20.            (setq sl (getdist "\nEnter segement length: "))
  21.       )
  22.     (progn ; create pline
  23.       (setq tl  (distance ps pe)
  24.             ang (angle ps pe)
  25.             pts (list ps)
  26.             di  sl
  27.       )
  28.       (while (< (distance ps (setq p (polar ps ang di))) tl)
  29.         (setq di  (+ sl di)
  30.               pts (cons p pts)
  31.         )
  32.       )
  33.       (makepline (cons pe pts) (getvar "clayer") 0)
  34.     )
  35.   )
  36.   (princ)
  37. )
« Last Edit: February 02, 2012, 03:53:48 PM by CAB »
« Reply #4 on: February 02, 2012, 02:35:59 PM »
Another, quick one:
  1. (defun c:pldiv ( / d1 d2 el i pl sl )
  2.     (setq el (entlast))
  3.     (command "_.pline")
  4.     (while (= 1 (logand 1 (getvar 'CMDACTIVE)))
  5.         (command pause)
  6.     )
  7.     (if
  8.         (and
  9.             (not (equal el (setq el (entlast))))
  10.             (progn
  11.                 (initget 6)
  12.                 (setq sl (getdist "\nSpecify Segment Length: "))
  13.             )
  14.         )
  15.         (progn
  16.             (setq i 0)
  17.             (repeat (fix (vlax-curve-getendparam el))
  18.                 (setq d1 (vlax-curve-getdistatparam el i)
  19.                       d2 (vlax-curve-getdistatparam el (1+ i))
  20.                 )
  21.                 (while (< d1 d2)
  22.                     (setq pl (cons (cons 10 (vlax-curve-getpointatdist el d1)) pl)
  23.                           d1 (+ d1 sl)
  24.                     )
  25.                 )
  26.                 (setq i (1+ i))
  27.             )
  28.             (if
  29.                 (entmake
  30.                     (append
  31.                         (list
  32.                            '(0 . "LWPOLYLINE")
  33.                            '(100 . "AcDbEntity")
  34.                            '(100 . "AcDbPolyline")
  35.                             (cons 90 (length pl))
  36.                             (assoc 70 (entget el))
  37.                         )
  38.                         (reverse pl)
  39.                     )
  40.                 )
  41.                 (entdel el)
  42.             )
  43.         )
  44.     )
  45.     (princ)
  46. )
demesne
« Reply #5 on: February 02, 2012, 03:37:00 PM »
Blimey!  Thanks guys.
They both would save me time.
CAB (or do you prefer Charles?) - your routine missed the last segment meaning the line is shorter than the pick points, but I could live with that. Many thanks.
Lee - works perfectly.  I think I owe you a beer!  Thanks again.
Regards
Demesne
« Reply #6 on: February 02, 2012, 03:44:32 PM »
Oops, code updated.
« Reply #7 on: February 02, 2012, 03:53:14 PM »
Here is another version for number of segments. (little testing)
  1. (defun c:pldivide2 (/ ps pe sl sc tl ang di pts)
  2.
  4.     (entmakex
  5.       (append
  9.               (cons 8 "0")
  12.         )
  14.       )
  15.     )
  16.   )
  17.
  20.            (setq sc (getint "\nEnter number of segements : "))
  21.       )
  25.             pts (list ps)
  26.             sl  (/ tl sc)
  27.             di  sl
  28.       )
  29.       (while (< (distance ps (setq p (polar ps ang di))) tl)
  30.         (setq di  (+ sl di)
  31.               pts (cons p pts)
  32.         )
  33.       )
  34.       (makepline (cons pe pts) (getvar "clayer") 0)
  35.     )
  36.   )
  37.   (princ)
  38. )
demesne
« Reply #8 on: February 02, 2012, 05:23:47 PM »
Thanks.  That's how I've always wanted the standard AutoCAD 'divide' command to work.
Excellent!
« Reply #9 on: February 02, 2012, 05:44:10 PM »
Excellent to hear - you're welcome Demesne  :-)
alanjt
  • Standby for witty remark...
« Reply #10 on: February 03, 2012, 10:17:33 AM »
Slight, pointless mod on Lee's (entmod rather than entmake+entdel)...
(defun c:pldiv (/ d1 d2 el i pl sl)
  (setq el (entlast))
  (command "_.pline")
    (command pause)
  (if (and (not (equal el (setq el (entlast))))
           (progn (initget 6) (setq sl (getdist "\nSpecify Segment Length: ")))
      (setq i 0)
        (while (< d1 d2)
                d1 (+ d1 sl)
        (setq i (1+ i))
      (entmod (append (vl-remove-if (function (lambda (x) (member (car x) '(10 90)))) (entget el))
                      (cons (cons 90 (length pl)) (reverse pl))
Dropbox
