Author Topic: Command input  (Read 4850 times)
Command input
« on: December 18, 2006, 11:22:13 AM »
Command line for the most part, a few toolbars and pull-downs.
Re: Command input
« Reply #1 on: December 18, 2006, 11:24:30 AM »
I like the most amount of drawing realestate, so all I have at most is two rows of toolbars across the top.  No toolpallets.  I type most of my commands in, or pick from my special middle mouse button menu, or from the pull downs.
David Hall
  • Automatic Duh Generator
Re: Command input
« Reply #2 on: December 18, 2006, 11:32:07 AM »
Command line for most everything.  Which includes 2 key shortcuts I program for everything that is not a fast input
Krushert
  • FREE BEER Tomorrow!!
Re: Command input
« Reply #3 on: December 18, 2006, 12:04:11 PM »
Same here.  1 custom tool bar & 1 custom pull down.  I really heavily on the right click menu, properties palette, pgp file and lisp.
hudster
Re: Command input
« Reply #4 on: December 18, 2006, 12:16:30 PM »
I use dynamic input practically all of the time.
Dilbert
Re: Command input
« Reply #5 on: December 18, 2006, 12:24:01 PM »
Dynamic input and the Toolpalettes (of course I use ADT more which has a lot of custom walls/doors/windows which are only convenient on the palettes).
StykFacE
Re: Command input
« Reply #6 on: December 18, 2006, 02:33:43 PM »
command line FTW, + my own custom *.pgp file for even quicker commands. also right-click mouse button is disabled as Enter. fa shizzle.
also, Tool Palettes FTW. i use the crap outta my Tool Palettes when drawing my HVAC plans.
« Last Edit: December 18, 2006, 02:35:54 PM by StykFacE »
M-dub
Re: Command input
« Reply #7 on: December 18, 2006, 02:41:13 PM »
Command line for the majority of it.  I also have a few toolbars where I have macros and lisp routine access.
It's Alive!
  • Retired
  • AKA Daniel
Re: Command input
« Reply #8 on: December 18, 2006, 02:42:18 PM »
I use the command line the most, I have a Gateway programmable keyboard , an X-Keys key pad and I use AutoHotKey.  :-)
Dan
Re: Command input
« Reply #9 on: December 18, 2006, 03:05:38 PM »
Command line and accelarator keys
Birdy
Re: Command input
« Reply #10 on: December 18, 2006, 03:13:11 PM »
command line here mostly.
One toolbar across the top.
Never used properties palette, or tool palettes much till I got dual monitors.  Now I use them more and more....but still a command line junkie.  Most stuff one or two key aliases.
Re: Command input
« Reply #11 on: December 18, 2006, 07:11:56 PM »
I use the command line almost exclusively, although I do have a few toolbars ... ok so I have ALOT of toolbars ... but most of them are customized for executing multiple commands in succession ... for example I have one that renames a specific dimension style, creates a new dimension style, purges all dimension overrides, zooms to extents, purges all unused layers, removes non graphical blocks, cleans all null text, then finally wblocks the drawing to itself to remove any stragling crap I missed. It takes all of 2 seconds to do .. of course I could simply create a lisp or VBA to do all of those things .. but hey I am lazy before I am a programmer.
Bryco
Re: Command input
« Reply #12 on: December 18, 2006, 08:03:40 PM »
Autocad please don't mess with the command line, I know it's looked the same for ever and it works but that doesn't mean you have to mess with it.
Dinosaur
Re: Command input
« Reply #13 on: December 18, 2006, 09:15:38 PM »
Command line for the most part, a few toolbars and pull-downs . . .
How are you managing that in Civil 3D?  I had to leave many of my command line tools behind when I jumped to Civil 3D . . . I only use a select few anymore and only when I am doing strictly AutoCAD functions.  I have to hold my nose and use the pulldowns and toolbars more than I care to, but I am growing quite fond of the right click and double click context menus.  I guess most of the work now happens in a tool palette if that is where you classify Toolspace.
jonesy
  • SuperMod
Re: Command input
« Reply #14 on: December 19, 2006, 02:28:51 AM »
Currently I use the command line the most, but with each new tool I hack together, I'm finding I use the toolbars, pull-downs and increasingly tool-palettes more and more.
