Author Topic: (C3D 2016) Export Points to Lat Long  (Read 2858 times)
« on: March 01, 2016, 02:55:06 PM »
So i'm exporting points from my FL state plane dwg to WGS84 (LAT LONG) so i can import them into maps.google.com. I get points in lat-long but in the wrong place! For example.
exported - 27.562183,-82.272392
google maps - 27.939330, -82.456792
They are close, as in the same county. LOL But not close enough to work with. Any ideas? I'm stumped on this one.
thanks
Re: (C3D 2016) Export Points to Lat Long
« Reply #1 on: March 01, 2016, 03:03:48 PM »
thanks
could be that google actually uses WGS 84 Psuedo Mercator NOT actual WGS84 - or       4326    vs   3857
« Reply #2 on: March 01, 2016, 03:06:26 PM »
If I export feature lines to a KML file they come in correctly. *shrug* But I need points.
« Reply #3 on: March 01, 2016, 03:16:32 PM »
The problem is C3D is not actually converting to decimal degrees.
27.562183 (N027° 56' 21.83"),-82.272392 (W082° 27' 23.92")
« Reply #4 on: March 01, 2016, 03:24:35 PM »
and just for fun, changing the following settings does nothing.
« Reply #5 on: March 01, 2016, 03:26:28 PM »
OK set up your point file format and CHOOSE DECDEGRESS  it's further down the list
« Reply #6 on: March 01, 2016, 03:49:53 PM »
BOOM!! Perfect.
Thankyaverymuch.
