Code Red => AutoLISP (Vanilla / Visual) => Topic started by: kruuger on March 22, 2017, 11:10:48 AM
hello
is it possible to add dictionary with dbx?
like:
(cd:DCT_AddDict (namedobjdict) "ADS_SETTINGS")
thanks
As in, using ObjectDBX to side-load a file? Yes, it is. If that's an "AutoCAD owned" dictionary ("ADS" rings a bell) you're responsible for getting everything right.
You are right but you have to use VL functions to do so. Using entmake is not possible in this case.
Essentially use the following process applied to an ObjectDBX Document object:
- vla-get-dictionaries applied to ObjectDBX Document object to obtain Dictionaries Collection
- vl-catch-all-apply 'vla-item on Dictionaries Collection to check if target dictionary already exists
- If dictionary doesn't exist, vla-add to Dictionaries Collection with dictionary name to create it
- vl-catch-all-apply 'vla-getobject on Dictionary object to check if target xrecord already exists
- If xrecord doesn't exist, vla-addxrecord to Dictionary object with xrecord name to create it
- vla-getxrecorddata to obtain existing xrecord data
- vla-setxrecorddata to set xrecord data
hi Lee, thanks for the list. will see if i can handle this.
kruuger
