; Program Name: GetExcel.lsp [GetExcel R4]
; Created By: Terry Miller (Email: terrycadd@yahoo.com)
; (URL: http://web2.airmail.net/terrycad)
; Date Created: 9-20-03
; Function: Several functions to get and put values into Excel cells.
; Revision History
; Rev By Date Description
; 1 TM 9-20-03 Initial version
; 2 TM 8-20-07 Rewrote GetExcel.lsp and added several new sub-functions
; including ColumnRow, Alpha2Number and Number2Alpha written
; by Gilles Chanteau from Marseille, France.
; 3 TM 12-1-07 Added several sub-functions written by Gilles Chanteau
; including Cell-p, Row+n, and Column+n. Also added his
; revision of the PutCell function.
; 4 GC 9-20-08 Revised the GetExcel argument MaxRange$ to accept a nil
; and get the current region from cell A1.
; Overview of Main functions
; GetExcel - Stores the values from an Excel spreadsheet into *ExcelData@ list
; Syntax: (GetExcel ExcelFile$ SheetName$ MaxRange$)
; Example: (GetExcel "C:\\Folder\\Filename.xls" "Sheet1" "L30")
; GetCell - Returns the cell value from the *ExcelData@ list
; Syntax: (GetCell Cell$)
; Example: (GetCell "H15")
; Function example of usage:
; (defun c:Get-Example ()
; (GetExcel "C:\\Folder\\Filename.xls" "Sheet1" "L30");<-- Edit Filename.xls
; (GetCell "H21");Or you can just use the global *ExcelData@ list
; );defun
; OpenExcel - Opens an Excel spreadsheet
; Syntax: (OpenExcel ExcelFile$ SheetName$ Visible)
; Example: (OpenExcel "C:\\Folder\\Filename.xls" "Sheet1" nil)
; PutCell - Put values into Excel cells
; Syntax: (PutCell StartCell$ Data$) or (PutCell StartCell$ DataList@)
; Example: (PutCell "A1" (list "GP093" 58.5 17 "Base" "3'-6 1/4\""))
; CloseExcel - Closes Excel session
; Syntax: (CloseExcel ExcelFile$)
; Example: (CloseExcel "C:\\Folder\\Filename.xls")
; (defun c:Put-Example ()
; (OpenExcel "C:\\Folder\\Filename.xls" "Sheet1" nil);<-- Edit Filename.xls
; (PutCell "A1" (list "GP093" 58.5 17 "Base" "3'-6 1/4\""));Repeat as required
; (CloseExcel "C:\\Folder\\Filename.xls");<-- Edit Filename.xls
; (princ)
; );defun
; Note: Review the conditions of each argument in the function headings
; Arguments: 3
; ExcelFile$ = Path and filename
; SheetName$ = Sheet name or nil for not specified
; MaxRange$ = Maximum cell ID range to include or nil to get the current region from cell A1
; Syntax examples:
; (GetExcel "C:\\Temp\\Temp.xls" "Sheet1" "E19") = Open C:\Temp\Temp.xls on Sheet1 and read up to cell E19
; (GetExcel "C:\\Temp\\Temp.xls" nil "XYZ123") = Open C:\Temp\Temp.xls on current sheet and read up to cell XYZ123
(defun GetExcel (ExcelFile$ SheetName$ MaxRange$ / Column# ColumnRow@ Data@ ExcelRange^
ExcelValue ExcelValue ExcelVariant^ MaxColumn# MaxRow# Range$ Row# Worksheet)
(if (= (type ExcelFile$) 'STR)
(if (not (findfile ExcelFile$))
(alert (strcat "Excel file " ExcelFile$ " not found."))
(exit)
);progn
);if
(alert "Excel file not specified.")
(exit)
);progn
);if
(gc)
(if (setq *ExcelApp% (vlax-get-object "Excel.Application"))
(alert "Close all Excel spreadsheets to continue!")
(vlax-release-object *ExcelApp%)(gc)
);progn
);if
(setq ExcelFile$ (findfile ExcelFile$))
(setq *ExcelApp% (vlax-get-or-create-object "Excel.Application"))
(vlax-invoke-method (vlax-get-property *ExcelApp% 'WorkBooks) 'Open ExcelFile$)
(if SheetName$
(vlax-for Worksheet (vlax-get-property *ExcelApp% "Sheets")
(if (= (vlax-get-property Worksheet "Name") SheetName$)
(vlax-invoke-method Worksheet "Activate")
);if
);vlax-for
);if
(if MaxRange$
(setq ColumnRow@ (ColumnRow MaxRange$))
(setq MaxColumn# (nth 0 ColumnRow@))
(setq MaxRow# (nth 1 ColumnRow@))
);progn
(setq CurRegion (vlax-get-property (vlax-get-property
(vlax-get-property *ExcelApp% "ActiveSheet") "Range" "A1") "CurrentRegion")
);setq
(setq MaxRow# (vlax-get-property (vlax-get-property CurRegion "Rows") "Count"))
(setq MaxColumn# (vlax-get-property (vlax-get-property CurRegion "Columns") "Count"))
);progn
);if
(setq *ExcelData@ nil)
(setq Row# 1)
(repeat MaxRow#
(setq Data@ nil)
(setq Column# 1)
(repeat MaxColumn#
(setq Range$ (strcat (Number2Alpha Column#)(itoa Row#)))
(setq ExcelRange^ (vlax-get-property *ExcelApp% "Range" Range$))
(setq ExcelVariant^ (vlax-get-property ExcelRange^ 'Value))
(setq ExcelValue (vlax-variant-value ExcelVariant^))
(setq ExcelValue
((= (type ExcelValue) 'INT) (itoa ExcelValue))
((= (type ExcelValue) 'REAL) (rtosr ExcelValue))
((= (type ExcelValue) 'STR) (vl-string-trim " " ExcelValue))
((/= (type ExcelValue) 'STR) "")
);cond
);setq
(setq Data@ (append Data@ (list ExcelValue)))
(setq Column# (1+ Column#))
);repeat
(setq *ExcelData@ (append *ExcelData@ (list Data@)))
(setq Row# (1+ Row#))
);repeat
(vlax-invoke-method (vlax-get-property *ExcelApp% "ActiveWorkbook") 'Close :vlax-False)
(vlax-invoke-method *ExcelApp% 'Quit)
(setq *ExcelApp% nil)
*ExcelData@
);defun GetExcel
; Arguments: 1
; Cell$ = Cell ID
; Syntax example: (GetCell "E19") = value of cell E19
(defun GetCell (Cell$ / Column# ColumnRow@ Return Row#)
(setq ColumnRow@ (ColumnRow Cell$))
(setq Column# (1- (nth 0 ColumnRow@)))
(setq Row# (1- (nth 1 ColumnRow@)))
(setq Return "")
(if *ExcelData@
(if (and (>= (length *ExcelData@) Row#)(>= (length (nth 0 *ExcelData@)) Column#))
(setq Return (nth Column# (nth Row# *ExcelData@)))
);if
);if
Return
);defun GetCell
; Arguments: 3
; ExcelFile$ = Excel filename or nil for new spreadsheet
; Visible = t for visible or nil for hidden
; Syntax examples:
; (OpenExcel "C:\\Temp\\Temp.xls" "Sheet2" t) = Opens C:\Temp\Temp.xls on Sheet2 as visible session
; (OpenExcel "C:\\Temp\\Temp.xls" nil nil) = Opens C:\Temp\Temp.xls on current sheet as hidden session
; (OpenExcel nil "Parts List" nil) = Opens a new spreadsheet and creates a Part List sheet as hidden session
(defun OpenExcel (ExcelFile$ SheetName$ Visible / Sheet$ Sheets@ Worksheet)
(if (findfile ExcelFile$)
(setq *ExcelFile$ ExcelFile$)
(exit)
);progn
);if
(setq *ExcelFile$ "")
);if
(gc)
);progn
);if
(if ExcelFile$
(vlax-invoke-method (vlax-get-property *ExcelApp% 'WorkBooks) 'Add)
);if
);if
(if Visible
(vla-put-visible *ExcelApp% :vlax-true)
);if
(if (= (type SheetName$) 'STR)
(vlax-for Sheet$ (vlax-get-property *ExcelApp% "Sheets")
(setq Sheets@ (append Sheets@ (list (vlax-get-property Sheet$ "Name"))))
);vlax-for
(if (member SheetName$ Sheets@)
);if
);vlax-for
(vlax-put-property (vlax-invoke-method (vlax-get-property *ExcelApp% "Sheets") "Add") "Name" SheetName$)
);if
);progn
);if
);defun OpenExcel
; Arguments: 2
; StartCell$ = Starting Cell ID
; Data@ = Value or list of values
; Syntax examples:
; (PutCell "A1" "PART NUMBER") = Puts PART NUMBER in cell A1
; (PutCell "B3" '("Dim" 7.5 "9.75")) = Starting with cell B3 put Dim, 7.5, and 9.75 across
(defun PutCell (StartCell$ Data@ / Cell$ Column# ExcelRange Row#)
(if (= (type Data@) 'STR)
(setq Data@ (list Data@))
(setq ExcelRange (vlax-get-property *ExcelApp% "Cells"))
(if (Cell-p StartCell$)
(setq Column# (car (ColumnRow StartCell$))
Row# (cadr (ColumnRow StartCell$))
);setq
(if (vl-catch-all-error-p
(setq Cell$ (vl-catch-all-apply 'vlax-get-property
(list (vlax-get-property *ExcelApp% "ActiveSheet") "Range" StartCell$))
);setq
);vl-catch-all-error-p
(alert (strcat "The cell ID \"" StartCell$ "\" is invalid."))
(setq Column# (vlax-get-property Cell$ "Column")
Row# (vlax-get-property Cell$ "Row")
);setq
);if
);if
(if (and Column# Row#)
(foreach Item Data@
(vlax-put-property ExcelRange "Item" Row# Column# (vl-princ-to-string Item))
);foreach
);if
);defun PutCell
; CloseExcel - Closes Excel spreadsheet
; Arguments: 1
; ExcelFile$ = Excel saveas filename or nil to close without saving
; Syntax examples:
; (CloseExcel "C:\\Temp\\Temp.xls") = Saveas C:\Temp\Temp.xls and close
; (CloseExcel nil) = Close without saving
(defun CloseExcel (ExcelFile$ / Saveas)
(if ExcelFile$
(if (= (strcase ExcelFile$) (strcase *ExcelFile$))
(vlax-invoke-method (vlax-get-property *ExcelApp% "ActiveWorkbook") "Save")
(setq Saveas t)
);if
(vl-file-delete (findfile ExcelFile$))
(setq Saveas t)
);progn
(setq Saveas t)
);if
);if
);if
(if Saveas
"SaveAs" ExcelFile$ -4143 "" "" :vlax-false :vlax-false nil
);vlax-invoke-method
);if
(setq *ExcelApp% nil *ExcelFile$ nil)
);defun CloseExcel
; ColumnRow - Returns a list of the Column and Row number
; Function By: Gilles Chanteau from Marseille, France
; Arguments: 1
; Cell$ = Cell ID
; Syntax example: (ColumnRow "ABC987") = '(731 987)
(defun ColumnRow (Cell$ / Column$ Char$ Row#)
(setq Column$ "")
(while (< 64 (ascii (setq Char$ (strcase (substr Cell$ 1 1)))) 91)
(setq Column$ (strcat Column$ Char$)
Cell$ (substr Cell$ 2)
);setq
);while
(if (and (/= Column$ "") (numberp (setq Row# (read Cell$))))
(list (Alpha2Number Column$) Row#)
'(1 1);default to "A1" if there's a problem
);if
);defun ColumnRow
; Alpha2Number - Converts Alpha string into Number
; Arguments: 1
; Str$ = String to convert
; Syntax example: (Alpha2Number "ABC") = 731
(defun Alpha2Number (Str$ / Num#)
(if (= 0 (setq Num# (strlen Str$)))
0
(+ (* (- (ascii (strcase (substr Str$ 1 1))) 64) (expt 26 (1- Num#)))
(Alpha2Number (substr Str$ 2))
);if
);defun Alpha2Number
; Number2Alpha - Converts Number into Alpha string
; Arguments: 1
; Num# = Number to convert
; Syntax example: (Number2Alpha 731) = "ABC"
(defun Number2Alpha (Num# / Val#)
(if (< Num# 27)
(chr (+ 64 Num#))
(if (= 0 (setq Val# (rem Num# 26)))
(strcat (Number2Alpha (1- (/ Num# 26))) "Z")
(strcat (Number2Alpha (/ Num# 26)) (chr (+ 64 Val#)))
);if
);if
);defun Number2Alpha
; Cell-p - Evaluates if the argument Cell$ is a valid cell ID
; Arguments: 1
; Cell$ = String of the cell ID to evaluate
; Syntax examples: (Cell-p "B12") = t, (Cell-p "BT") = nil
(defun Cell-p (Cell$)
(and (= (type Cell$) 'STR)
(or (= (strcase Cell$) "A1")
(not (equal (ColumnRow Cell$) '(1 1)))
);or
);and
);defun Cell-p
; Row+n - Returns the cell ID located a number of rows from cell
; Arguments: 2
; Cell$ = Starting cell ID
; Num# = Number of rows from cell
; Syntax examples: (Row+n "B12" 3) = "B15", (Row+n "B12" -3) = "B9"
(defun Row+n (Cell$ Num#)
(setq Cell$ (ColumnRow Cell$))
(strcat (Number2Alpha (car Cell$)) (itoa (max 1 (+ (cadr Cell$) Num#))))
);defun Row+n
; Column+n - Returns the cell ID located a number of columns from cell
; Arguments: 2
; Num# = Number of columns from cell
; Syntax examples: (Column+n "B12" 3) = "E12", (Column+n "B12" -1) = "A12"
(defun Column+n (Cell$ Num#)
(strcat (Number2Alpha (max 1 (+ (car Cell$) Num#))) (itoa (cadr Cell$)))
);defun Column+n
; rtosr - Used to change a real number into a short real number string
; stripping off all trailing 0's.
; Arguments: 1
; RealNum~ = Real number to convert to a short string real number
; Returns: ShortReal$ the short string real number value of the real number.
(defun rtosr (RealNum~ / DimZin# ShortReal$)
(setq DimZin# (getvar "DIMZIN"))
(setvar "DIMZIN" 8)
(setq ShortReal$ (rtos RealNum~ 2 8))
(setvar "DIMZIN" DimZin#)
ShortReal$
);defun rtosr
(princ);End of GetExcel.lsp
Again, speaking to tables... our client doesn't tolerate Mtext. When you explode a table, all the text becomes MTEXT. I then have to explode it... Assuming the Mtext has an alignment of bottom center, when you explode it the text doesn't move, but by default, the anchor point becomes "LEFT" not center. I have to manually change the text from "LEFT" to "CENTER" and then re-align all the text to their expected positions. That's a lot of work for 10 columns by 300 dwgs. Rea-positioning 3000 pieces of text is not my idea of a fun time.
Thank you, I will give this a try Wednessday, and see what I can do with it...Hope it helps you out :)
Many thanks RonJonP
I just couldn't wait til Wednesday.The horizontal location is the largest text width of the current column being processed + the largest text width of the next column to be processed divided by 1.5 ( line 70 in the code above ) If you want to make the gaps larger, divide by a smaller number.
How does the script determine the horizontal location... I want to modify that to make the gap a bit wider..
I will get some more help with this after, but I will start a new thread. At first try this looks pretty awesome.
Some things I can likely change... don't need a prompt for the location.. it will always be the same point. However, wondering if I can set the horizontal locations. Right now it is pretty darn close, but If I can get that lined up, this may be doable pretty much as is.
Is anyone editing the column after it is created since the source is an excel file? If not, does the justification really matter? If it does, express tools has a command to change justification without moving text, TJUST
Maybe this version will cut your 10 minutes of time down to 2 ;) . I hard coded values based on that example drawing, so all you have to do is select your data.QuoteIs anyone editing the column after it is created since the source is an excel file? If not, does the justification really matter? If it does, express tools has a command to change justification without moving text, TJUST...
Manually this can take over an hour to do, but with the script provided by RONJONP this can be accomplished in about 10 min. It's pretty good. I would like to cut minutes down to seconds. I will be looking to tweak it a bit further, but the heavy lifting is done.
This is a constant problem for me.. as the project is supposed to be directed from the log, not the index.
At times, the engineer will take a short cut and update the index, and not the log, or the drawing sheets. Or, he/she will update the log and not tell any CAD technician.
...Here you go:
Is there a way we can make the gap jump 10" instead of .2 on every 51st line?
One more thing,
How do I add your credentials to the script.
It needs a proper author.
It should prompt when loaded "Writen by RonJonP from TheSwamp.org 06-21-2016" that would be sweet.
(princ "\nWritten by ronjonp @ TheSwamp 22-JUN-2016")
I'm not sure what's going on with the .lsp, but I do note that your .csv has a lot of empty lines at the end. Try opening it with notepad and deleting all those empty lines.Agreed .. there are approximately 1200 'empty' rows after your data. I fixed the code in the previous post so it would not error.
119,58-09-0274,684870SH07,COEN - COMBUSTION ENGINEERS,7 OF 9,2,FUNCTIONAL LOGIC DIAGRAM,BURNER MANAGEMENT SYSTEM ,SOME/ PLANT COMMON,REVISED,
120,58-09-0275,684870SH08,COEN - COMBUSTION ENGINEERS,8 OF 9,1,FUNCTIONAL LOGIC DIAGRAM,BURNER MANAGEMENT SYSTEM ,SOME/ PLANT COMMON,REVISED,
121,58-09-0276,684870SH09,COEN - COMBUSTION ENGINEERS,9 OF 9,2,FUNCTIONAL LOGIC DIAGRAM,BURNER MANAGEMENT SYSTEM ,SOME/ PLANT COMMON,REVISED,
122,DE-58-09-0,D0681870SH06,COEN - COMBUSTION ENGINEERS,6 OF 10,3,SCHEM & CONN DIAG,MFT RELAY PANEL,SOME/ PLANT COMMON,REVISED,
