perhaps if all those XXXXXXX's were actual numbers; a search might yield more usefull information?
•Microsoft SQL Server Management Studio: An error with a message like “Unable to cast COM object of type ‘System.__ComObject’ to interface type ‘Microsoft.VisualStudio.OLE.Interop.IServiceProvider’. This operation failed because the QueryInterface call on the COM component for the interface with IID ‘{6D5140C1-7436-11CE-8034-00AA006009FA}’ failed due to the following error: No such interface supported (Exception from HRESULT: 0×80004002 (E_NOINTERFACE)). (Microsoft.VisualStudio.OLE.Interop)
I’m not sure of the exact details, but this is what I think I’ve found. Perhaps someone at Microsoft would correct or elaborate on this.
Previously, actxprxy.dll (ActiveX Interface Marshaling Library) was used as the proxy for a multitude of system interfaces, such as IShellFolder and IServiceProvider.
In Windows 7 (and probably Vista also), the GUID of this library has changed from {B8DA6310-E19B-11D0-933C-00A0C90DCAA9} to {C90250F3-4D7D-4991-9B69-A5C5BC1C2AE6}
Secondly, there is also a new Proxy/Stub provider found in ieproxy.dll of Internet Explorer (IE ActiveX Interface Marshaling Library). Some interfaces that previously used actxprxy.dll are now registered to use ieproxy.dll.
Now various problematic software (such as Vault 3.x) will try to register against actxproxy using the old GUID, and for interfaces now proxied by ieproxy.dll.
