No, I understand that. I thought this was a coding question. If you set the put-NOC to a value, then the get-NOC to a variable, immediately after it, you should have the value contained and be able to reuse it within the same call or be sure and set the variable globally... Hmm. Just had a thought, if he wanted to go from drawing to drawing, even a variable in global scope wouldn't work. However, I wonder if vl-bb-set and -ref would be useful. I haven't messed with them in a while. Then again, a long workaround would be to write-line it to a txt file somewhere as write not append, then always call that info from the text file when plotting in another drawing.
