Code Red => AutoLISP (Vanilla / Visual) => Topic started by: TAIKI on May 16, 2015, 04:34:43 PM
Title: I need help with entnext
Post by: TAIKI on May 16, 2015, 04:34:43 PM
Hello
I want to move attribut name "alt"on block using ssget function to mark with a circle the insertion point of the block. So I don't understand how I can filter attribut. Please can you help me?
Title: Re: I need help with entnext
Post by: roy_043 on May 17, 2015, 02:10:51 PM
It is not completely clear to me what you want to do. But you cannot filter for a specific attribute with an ssget filter. But you can use ssget to filter for inserts with a given name and/or with attributes. But why don't you use nentsel to select the attribute?
Post by: TAIKI on May 17, 2015, 04:39:02 PM
I'll explain much better, I want to move the attribut "alt" not another and on the same time place place a circle on the insertion point of the block containing the attribut.
I use ssget to place the circle, but for filter the attribut to move I don't know how to do. With nentsel I can move attribut but I can't place the circle on insertion point of the block.
thanks for your help.
Post by: roy_043 on May 18, 2015, 04:00:04 AM
