Code Red => AutoLISP (Vanilla / Visual) => Topic started by: taner on August 02, 2007, 03:31:13 AM
(acet-error-init args)
Error handler.
Note:
This function should be paired with (acet-error-restore) below to encapsulate error handling for LISP functions or commands that may be aborted by the user.
Arguments
args A list containing up to three elements (described below).
Arguments are provided in a list to allow for future enhancements. The list can currently be nil or can contain up to three elements:
A list containing pairs of system variable names along with an initial value for each variable, in the form:
("sysvar" value "sysvar" value ...)
The (acet-error-init) function will preserve the initial value of these variables (see (acet-error-restore) below) and then set the new values.
A flag value indicating whether UNDO should be used as part of the error handling operation. This value can be one of: nil Do not use undo.
0 Enable Undo and place begin and end marks, but do not issue the UNDO command in the event of an error.
1 Enable Undo and use the UNDO command in the event of an error.
A quoted function call that will be executed as part of the error handling operation. A nil argument indicates that no additional error handling is required.
Return Values
nil
Example
(acet-error-init '(("CMDECHO" 0)
1
(if ename (redraw ename 4)) ) )
Reset error handling.
This function restores the values saved by the matching call to (acet-error-init). It should be called after all user input has been completed. This function ends with a (princ) call for a quiet finish.
Return Values
nil
Library: acetutil.fas
Someone has to, so it may as well be me ..
Why do you want to rewrite it ?
a) It works fine as far as I know, and
b) there are probably at least half a dozen versions with similar functionality on this site alone ..
... but in answer to your actual question ; there are several people here who could/can rewrite it. Personally I'd need significant inducement.
You can.
Take the error handle i did and add-to/alter-it to fit your needs.
Tanar
Welcome to the swamp.
Use the Search option at the top of this page to find the error handler codes mentioned above.
Welcome to the swamp Taner.
Thanks all!
I have writen some code to put on the beginning and the end of the program as below,
- (defun tt-begin (varlst / sysnamelst valuelst)
(command "undo" "be")
(if varlst
(setq *#$*sysvarnl*#$* (mapcar
'car
varlst
sysnamelst *#$*sysvarnl*#$*
valuelst (mapcar
'cadr
varlst
(defun myerr (errmsg)
(if (not (member errmsg '("console break" "Function Cancelled")))
(princ (strcat "\nError: " errmsg))
(tt-end)
(setq errtmp *error*)
(setq *error* myerr)
(if *#$*sysvarnl*#$*
(setq *#$*svarl*#$* (mapcar
'getvar
*#$*sysvarnl*#$*
(mapcar
'setvar
sysnamelst
valuelst
(defun tt-end ()
(command ".undo" "E")
(if *#$*svarl*#$*
(mapcar
'setvar
*#$*sysvarnl*#$*
*#$*svarl*#$*
(setq *error* errtmp)
(setq *#$*sysvarnl*#$* nil
*#$*svarl*#$* nil
errtmp nil
I want it call the undo end if the main program have used command,otherwise,do not call undo end.
how to realize it?
http://www.theswamp.org/index.php?topic=13730.0
I believe these are the actual routines from the .fas files. They're from a file that comes with a demo for a commercial program. There's no copyright statement or use restriction in the file, and the file remains available after the demo times out. There's no acet-ui-progress function in the lisp file.
;;Error Init for ET
(defun acet-error-init (errlist / syslist sysvar sysval)
(setq ET$OldErrorHandler *error*
*error* ET$ErrorHandler
(setq *error* '((MSG /) (ET$ErrorHandler msg)))
(setq ET$OldSysVars NIL)
;; previous sysvar values for Restore
(acet-ui-progress-done)
(setq ET$SysVars (car errlist)
errlist (cdr errlist)
(setq ET$UndoFlag (car errlist)
(setq ET$UndoCode (car errlist)
(setq ET$OldSysVars (cons (getvar "ucsicon") ET$OldSysVars))
(setq ET$OldSysVars (cons "ucsicon" ET$OldSysVars))
(setq syslist ET$SysVars)
(while syslist
(setq sysvar (car syslist)
syslist (cdr syslist)
(setq sysval (car syslist)
(if (and sysvar sysval)
(setq ET$OldSysVars (cons (getvar sysvar) ET$OldSysVars))
(setq ET$OldSysVars (cons sysvar ET$OldSysVars))
(setvar sysvar sysval)
(setvar "cmdecho" 0)
(if ET$UndoFlag
(command "_.undo" "_begin")
ET$OldSysVars
;;Error Restore for ET
(defun acet-error-restore (/ sysvar sysval)
(if ET$UndoFlag
(command "_.undo" "_end")
(while ET$OldSysVars
(setq sysvar (car ET$OldSysVars)
ET$OldSysVars (cdr ET$OldSysVars)
(setq sysval (car ET$OldSysVars)
ET$SysVars NIL
ET$UndoFlag NIL
ET$UndoCode NIL
(if ET$OldErrorHandler
(setq *error* ET$OldErrorHandler)
(setvar "highlight" 1)
(setvar "cmdecho" 1)
;;done progress
(defun acet-ui-progress-done (/)
(if ET$ProgressActive
(setq ET$ProgressActive (acet-ui-progress))
NIL
already solved.
varlst is the a list as '(("cmdecho" 0)("osmode" 512)...("clayer" "dim"))
mark,when the main program used command function,mark is set to t.otherwise nil.
(defun t2x2t (varlst mark / sysnamelst valuelst)
(setq undo$mark mark)
(if undo$mark
(if varlst
'car
varlst
valuelst (mapcar
'cadr
varlst
(2txt2)
'getvar
*#$*sysvarnl*#$*
(mapcar
'setvar
sysnamelst
valuelst
(defun 2txt2 ()
(if undo$mark
(if *#$*svarl*#$*
(mapcar
'setvar
*#$*sysvarnl*#$*
*#$*svarl*#$*
*#$*svarl*#$* nil
errtmp nil
The first few lines can be replaced
;; (setq undo$mark mark)
;; (if undo$mark
;; (command "undo" "be")
(set undo$mark (if mark mark))
That is about as far as i have time to look into today.
;; (if undo$mark
I do not understand why, could you please explain it more clearly. thanks a lot.
Oops, i commented out to many lines. sorry, i was going to fast. But a quick retype will be as below.
``set'' is much the same as `setq' but it will evaluate its argument. Therefore my statement is saying, ``If mark is not nil set the variable to its value otherwise keep the var nil''.
(set 'undo$mark (if mark (progn (command "undo" "be") mark)))
I looked at your code a bit more and i noticed a potential problem i think; what about the `clayer' var. you will not have a value when you ``setvar clayer''. It was a problem i noticed in my own error trap procedure i had to account for later.
