Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
ACAD with .NET8+
Topic:
Playing with: Simple Pattern matching in if statement
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Playing with: Simple Pattern matching in if statement (Read 739 times)
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
class keyThumper<T>:ILazy<T>
on:
January 03, 2024, 06:11:46 PM »
Code - C#:
[Select]
global
using
static
System
Console
// just to save noise writing Console. prefix
// Add and remove the "" to change object o between string and int.
object
o
"3"
int
j
4
if
o
is
int
i
// <= here be magic !
WriteLine
"{i} x {j} = {i * j}"
else
WriteLine
"o is not an int so it cannot multiply!"
Logged
Called Kerry in my other life
I live at UTC + 13.00
King Gator
(x-in)->[process]->(y-out) ... simples!
WWW
Re: Playing with: Simple Pattern matching in if statement
Reply #1 on:
January 03, 2024, 07:33:37 PM »
nice!
Logged
- John Carmack
- J.R.R. Tolkien
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
Reply #2 on:
January 04, 2024, 01:04:02 AM »
Yes Mick,
There has been a lot of nice stuff in the last 5 or 6 years that has been ignored because we were stuck with Framework 4.8
I just need to wrap my old brain around it all
Logged
gile
Gator
Marseille, France
WWW
Reply #3 on:
January 04, 2024, 02:16:08 AM »
Hi Kerry,
This was already available with C# 7 (and .NET Framework), see
this topic
Logged
gile
Gator
Marseille, France
WWW
Reply #4 on:
January 04, 2024, 03:42:37 AM »
The same can been written with a switch statement (C# 7):
Code - C#:
[Select]
switch
o
case
int
i
WriteLine
break
default
WriteLine
break
C# 8 introduced "switch expressions":
Code - C#:
[Select]
WriteLine
o
switch
int
i
_
Logged
kdub_nz
Mesozoic keyThumper
SuperMod
Water Moccasin
Reply #5 on:
January 04, 2024, 04:21:37 AM »
Thanks Gilles,
I missed that.
Logged
gile
Gator
Marseille, France
WWW
Reply #6 on:
January 04, 2024, 05:31:24 PM »
This way also works:
Code - C#:
[Select]
WriteLine
o
is
int
i
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
.NET
ACAD with .NET8+
Topic:
