Author Topic: Mech vs Vanilla Version Number  (Read 4689 times)
MeasureUp
« on: February 15, 2011, 06:56:21 PM »
I have mech versions through 2005~2011 but vanilla versions.
I am wondering if there are any difference for the result when using "acadver".
The real question is that how to identify the vanilla and mech version.
Thanks for your help.
HofCAD
Re: Mech vs Vanilla Version Number
« Reply #1 on: February 16, 2011, 03:49:09 AM »
If you go with the command OPTIONS to the tab Profiles,
do you see then the Available Profiles 'Vanilla' and 'AcadM'.
The profile 'Vanilla' is for pure AutoCAD, and 'AcadM' is for
AutoCAD Mechanical.
Regards HofCAD CSI.
MeasureUp
« Reply #2 on: February 16, 2011, 04:14:37 AM »
Sorry, I mean that how to identify the mech/vanilla version in Autolisp.
« Reply #3 on: February 16, 2011, 07:51:38 AM »
I don't have time to test fully, but :
Mechanical is simply Vanilla AutoCAD with Add-ons.
If you manually compare the resulting list from (ARX) at the commandline you will see the different ARX files loaded into Mechanical
"acadm.arx" and "acadmmx.arx" may be a good place to start
So something like the following may assist you (untested)
(if (member "acadm.arx" (arx))
 (alert "This is Mechanical")
« Reply #4 on: February 16, 2011, 07:52:16 AM »
Check here, you can use the path method. But there must be another way.
http://www.theswamp.org/index.php?topic=36606.0
HofCAD
« Reply #5 on: February 16, 2011, 11:49:33 AM »
Try this:
(defun c:MechOrVanil(/ @getActiveProfile Prof)
(defun @getActiveProfile ()
  (vla-get-activeprofile
    (vla-get-profiles (vla-get-preferences (vlax-get-acad-object)))
(setq Prof (strcase (@getActiveProfile)))
 ((= Prof "ACADM") (princ "\nAutoCAD"))
 ((= Prof "ACADMPP") (princ "\nAutoCAD"))
 ((= Prof "VANILLA") (princ "\nAutoCAD Mechanical"))
 (t (princ "\nNo basic profile"))
Regards HofCAD CSI.
« Last Edit: February 17, 2011, 03:23:01 AM by HofCAD »
MeasureUp
« Reply #6 on: February 16, 2011, 04:47:37 PM »
Thanks, Kerry.
Totally agree with you.
This is a nice idea.
MeasureUp
« Reply #7 on: February 16, 2011, 04:55:38 PM »
Yes, I had something similar last night.
"C:\\program files\\autodesk\\acadm 2011\\..."
Thanks, CAB.
MeasureUp
« Reply #8 on: February 16, 2011, 05:00:53 PM »
Try this:
Regards HofCAD CSI.
This is nice, too.
Thanks, HofCAD
cmwade77
« Reply #9 on: February 16, 2011, 05:17:25 PM »
You can't rely on Profiles, every profile here is BEI, so I had to use the path method when I needed to do this, it is the only sure fire way that I have found.
alanjt
  • Standby for witty remark...
« Reply #10 on: February 16, 2011, 05:33:51 PM »
(vla-get-caption (vlax-get-acad-object))
Dropbox
« Reply #11 on: February 16, 2011, 05:53:49 PM »
Nice idea Alan  8-)
alanjt
« Reply #12 on: February 16, 2011, 05:55:14 PM »
Dropbox
« Reply #13 on: February 16, 2011, 06:18:34 PM »
Nice idea Alan :-) .. you'll need to account for (setenv "ShowFullPathInTitle" "1") which shows the path of the drawing opened.
"AutoCAD 2009 - [Drawing1.dwg]"
Perhaps something like:
(defun woohoo2 (/ p caption)
  (setq caption (vla-get-caption (vlax-get-acad-object)))
  (if (setq p (vl-string-position (ascii "-") caption))
    (substr caption 1 (1- p))
    caption
(woohoo2)
MeasureUp
« Reply #14 on: February 16, 2011, 06:31:58 PM »
I like this. Thanks, Alan.
