;;; "User Friendly Layer Setup" ;;; layersetup1.lsp ;;; By: Jon Nelson ;;; DFTG1352 ;;; Thomas Longnecker ;;; Altered and commented by someone else ;;; Ripped apart for altered use by another (defun c:layersetup () (vl-load-com) (setq num 1 name "DIM" reset (getvar 'clayer) cnt 1) (initget 7) ;I initially put 6. Edited to make it better. (setq rept (getint "\nHow many layers do you want?: ")) (repeat rept (if (> cnt 9) (setq layName (strcat name (rtos cnt 2 0))) (setq layName (strcat name "0" (rtos cnt 2 0))) ) (setq cnt (1+ cnt)) (if (snvalid layName) (setq n (append (list layName) n)) (setq tn nil) ) ) (foreach item n (command "Layer" "m" item "c" 5 "" "") ) (setvar 'clayer reset) (princ) ) (prompt "Enter LAYERSETUP to start")
(defun C:ADDLAYERS () ;; put whatever color number here (makeLayers 5) ) (defun makeLayers (cnum / cnt ctrl layname laynum laypref zero zeroln) (setq ctrl 0) (initget 6) (cond ((and (numberp cnum) (setq laynum (getint "\nNumber of layers: "))) (initget 128 "Dim") (setq laypref (cond ((setq laypref (getkword "\nLayer prefix <Dim>: ")) (setq laypref (strcase laypref))) ("DIM"))) (setq cnt 1 zeroln (strlen (strcat laypref (itoa laynum))) zero "" ) (repeat laynum (repeat (- zeroln (strlen (strcat laypref (itoa cnt)))) (setq zero (strcat zero "0")) ) (setq layname (strcat laypref zero (itoa cnt)) cnt (1+ cnt) zero "" ) (if (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") (cons 2 layname) (cons 62 cnum) '(70 . 0))) (setq ctrl (1+ ctrl)) ) ) ) ) (princ (strcat "\n" (itoa ctrl) " layers created")) (princ) )
(defun c:LayerCreator ( / lo num ll) (vl-load-com) (setq lo (vla-get-layers (vla-get-activedocument (vlax-get-acad-object) ) ) ) (initget 7) (setq num (getint "\nHow many dim layers to create? (must be < 200) : ")) (if (and num (< num 200)) (while (> num 0) (cond ((< num 10) (setq ll (cons (strcat "DIM0"(itoa num)) ll))) (T (setq ll (cons (strcat "DIM"(itoa num)) ll)) ) ) (setq num (1- num)) ); while ; else (prompt (strcat "\nAre you kidding..."(itoa num)" layers....")) ); if (if ll (mapcar '(lambda (x / newlayer) (setq newlayer (vla-add lo x)) (vlax-put-property newlayer 'Color 5) (vlax-release-object newlayer) ) ll) ); if (if (not (vlax-object-released-p lo)) (vlax-release-object lo)); if (princ) ); defun
And the result is ... !!!! Two tests were done. One for each command in a fresh drawing each (called 15 times) and one in the same drawing where the commands were called in this sequence (called 10 times each): AddLayer, LayerSetup, LayerCreator LayerSetup, LayerCreator, AddLayer LayerCreator, AddLayer, LayerSetup Each command set up 100 layers and was followed by garbage collection, purge and garbage collection. Timer was started as soon as user inputs were done. The code below shows were timers were started and ended in each routine along with the timer and cleanup code used. First, the results!! Unit is in seconds
New drawings, only one command used in each drawing LayerSetup AddLayers LayerCreator 0,515989 0,046992 0,094025 0,968975 0,061999 0,093985 1,547004 0,046992 0,092979 2,124994 0,046992 0,092979 2,735008 0,061999 0,078978 3,391009 0,063005 0,094025 4,157008 0,063005 0,094025 5,640001 0,063005 0,092978 6,531005 0,047033 0,109997 7,344036 0,061999 0,092978 8,296998 0,063005 0,094025 9,218015 0,061999 0,109032 10,436998 0,063005 0,108992 11,264996 0,063005 0,093019 12,202991 0,063005 0,108992 Averages: 5,758335 0,058469 0,096734 Same drawing, called in sequence as mentioned LayerSetup AddLayers LayerCreator 0,484005 0,045986 0,092979 1,078070 0,046992 0,078012 1,922017 0,045986 0,078012 2,688016 0,063005 0,109997 3,592980 0,077972 0,108992 4,922001 0,061999 0,108992 6,077980 0,078012 0,108992 7,280990 0,078978 0,108992 9,188001 0,078012 0,108992 10,671034 0,078012 0,108992 Averages: 4,790509 0,065495 0,101295
Notice anything in particular with the command pipeline in each test? Here's the code:
(defun startTimer () (setq time (getvar "DATE")) ) (defun endTimer (func) (setq time (- (getvar "DATE") time) seconds (* 86400.0 (- time (fix time))) ) (gc) (outPut seconds func) ) (defun outPut (secs def) (princ "\nPurging...") (command "PURGE" "Layers" "*" "N") (gc) (princ (strcat "\nTimed " def ": " (rtos secs 2 6))) (princ) ) (defun C:ADDLAYERS () ;; put whatever color number here (makeLayers 5) ) (defun makeLayers (cnum / cnt ctrl layname laynum laypref zero zeroln) (setq ctrl 0) (initget 6) (cond ((and (numberp cnum) (setq laynum (getint "\nNumber of layers: "))) (initget 128 "Dim") (setq laypref (cond ((setq laypref (getkword "\nLayer prefix <Dim>: ")) (setq laypref (strcase laypref))) ("DIM"))) (startTimer) (setq cnt 1 zeroln (strlen (strcat laypref (itoa laynum))) zero "") (repeat laynum (repeat (- zeroln (strlen (strcat laypref (itoa cnt)))) (setq zero (strcat zero "0"))) (setq layname (strcat laypref zero (itoa cnt)) cnt (1+ cnt) zero "") (if (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") (cons 2 layname) (cons 62 cnum) '(70 . 0))) (setq ctrl (1+ ctrl)))))) (princ (strcat "\n" (itoa ctrl) " layers created")) (princ) (endTimer (vl-symbol-name 'makeLayers)) ) (defun c:layersetup () (vl-load-com) (setq num 1 name "DIM" reset (getvar 'clayer) cnt 1) (initget 7) ;I initially put 6. Edited to make it better. (setq rept (getint "\nHow many layers do you want?: ")) (startTimer) (repeat rept (if (> cnt 9) (setq layName (strcat name (rtos cnt 2 0))) (setq layName (strcat name "0" (rtos cnt 2 0)))) (setq cnt (1+ cnt)) (if (snvalid layName) (setq n (append (list layName) n)) (setq tn nil))) (foreach item n (command "Layer" "m" item "c" 5 "" "")) (setvar 'clayer reset) (princ) (endTimer (vl-symbol-name 'c:layersetup)) ) (defun c:LayerCreator (/ lo num ll) (vl-load-com) (setq lo (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))) (initget 7) (setq num (getint "\nHow many dim layers to create? (must be < 200) : ")) (startTimer) (if (and num (< num 200)) (while (> num 0) (cond ((< num 10) (setq ll (cons (strcat "DIM0" (itoa num)) ll))) (T (setq ll (cons (strcat "DIM" (itoa num)) ll)))) (setq num (1- num))) ; while (prompt (strcat "\nAre you kidding..." (itoa num) " layers...."))) (if ll (mapcar '(lambda (x / newlayer) (setq newlayer (vla-add lo x)) (vlax-put-property newlayer 'Color 5) (vlax-release-object newlayer)) ll)) (if (not (vlax-object-released-p lo)) (vlax-release-object lo)) (princ) (endTimer (vl-symbol-name 'c:LayerCreator)) )
Very interesting Stig, I am truly enjoying this.I also tried creating 1000 layers with each. 1000 LAYERS Timed MAKELAYERS: 0.172037 Stig's Timed C:LAYERCREATOR: 0.297001 Mark's Timed C:LAYERSETUP: 4.264994 Daron's I'm going back to the pits for a tune up. <g>
Will be interesting to see if you can tune activex to match lisp inperformance. Just for the fun of it, I tried creating 12450 layers. AddLayers took 16seconds, LayerSet took 10 minutes - not to create the layers, though, but tofold with a fatal error! Never got around to test LayerCreator after that
12450 layers....... C:LAYERCREATOR: 15.125003
Yeah yeah, AFTER you changed to ENTMAKE I'm sure! heh Seriously, would you mind run AddLayers on your machine with 12450 layers? Ihate to admit it, but this is an OLD 500 MHz (don't laugh .. ok, laugh .. Ido!) PIII thingy.
12450 layers createdPurging...Timed MAKELAYERS: 4.547028
(PRV-DEF (:target . "drag_race.VLX") (:active-x . T) (:separate-namespace . T) (:protected . T) (:load-file-list (:lsp "DRAGRACE.LSP")) (:require-file-list) (:ob-directory) (:tmp-directory) (:optimization . lsa) )
I think most Civil 3D users can create that number of layers by simply opening one of the default templates....without using any code at all.
Is it difficult to change the lisp so that one can count up the layer with color.
(defun c:test ( / c n ) (setq c 0) (if (setq n (getint "\nNumber of Layers: ")) (repeat n (entmake (list '(0 . "LAYER") '(100 . "AcDbSymbolTableRecord") '(100 . "AcDbLayerTableRecord") (cons 2 (itoa n)) (cons 62 (setq c (1+ (rem c 255)))) '(70 . 0) ) ) (setq n (1- n)) ) ) (princ))
