Hello,
I'm trying to use old code from AutoCAD R12 .Net in a new AutoCAD R13 .Net program. However, when I do
<DllImport("acad.exe", CallingConvention:=CallingConvention.Cdecl, CharSet:=CharSet.Unicode, ExactSpelling:=True)> _
Private Shared Function acedSSGet(ByVal str As String, ByVal pt1 As IntPtr, ByVal pt2 As IntPtr, ByVal filter As IntPtr, ByRef ss As ads_name) As Autodesk.AutoCAD.EditorInput.PromptStatus
End Function
and I run the acedSSGet function it doesn't work. What DLL do I need to import?
Thanks,
cannorth
