Author Topic: how to use handle??  (Read 4973 times)
rainier
how to use handle??
« on: July 09, 2007, 03:35:12 AM »
hi guys, help me with my routine...
how to use handle??
sample:
(Command: (command "fillet" "r" "0" (handent "2D7A21") (handent "2D7A1F"))
<Entity name: 400E9448>
Unknown command "sample".  Press F1 for help.
<Entity name: 400E9438>
nil  ;<--- nil prompt
how to use it,,,
Re: how to use handle??
« Reply #1 on: July 09, 2007, 03:56:08 AM »
difficult without seeing your code.
Why are you using handles to identify entitys to fillet ?
What is the 'Sample' command you are trying to run ?
Adesu
« Reply #2 on: July 09, 2007, 04:26:11 AM »
you should like this
(defun c:test (/ el1 el2 pt1 pt2 pt3 pt4)
  (setq pt1 '(0 0 0))
  (setq pt2 '(10 0 0))
  (command "_line" pt1 pt2 "")
  (setq el1 (entlast))
  (setq en1 (entget el1))
  (setq ent1 (cdr (assoc 5 en1)))
  (setq ename1 (handent ent1))
  (setq pt3 '(10 0 0))
  (setq pt4 '(10 5 0))
  (command "_line" pt3 pt4 "")
  (setq el2 (entlast))
  (setq en2 (entget el2))
  (setq ent2 (cdr (assoc 5 en2)))
  (setq ename2 (handent ent2))
  (command "_fillet" "r" 3 "_fillet" ename1 ename2)
  ) ; defun
how to use handle??
sample:
how to use it,,,
rainier
« Reply #3 on: July 09, 2007, 05:32:54 AM »
thank you very much ADE, for me your a great Lisp programmer... wOw  :kewl: bravo
rainier
« Reply #4 on: July 09, 2007, 05:39:23 AM »
other thing...
how to change start point and end point of an Arc?
(if en (entsel "\n select arc:")
    (setq enlist (entget en))
    (setq vlaxobj (vlax-ename->vla-object en))
    (setq vlaxstartpt (vlax-get vlaxobj "StartPoint"))
    (setq vlaxendpt (vlax-get vlaxobj "EndPoint"))
    ; how to change the coordinated.... is there a way to change it..
    ; and entupd it or other update in vlax...?
please help...
« Reply #5 on: July 09, 2007, 08:14:16 AM »
There is no start or end point property.
Perhaps this will help you out. I don't remember the source for this code.
;;;The entity definition data of an arc doesn't reveal much direct information about that arc.
;;;All you get are: center point, start angle, end angle and radius.
;;;However, with a bit of math, you can get much more. Here's how:
;;; Returns a list containing both arc endpoints, arc length and chord length
(defun arc-info   (ent / lst cen rad ang1 ang2 p1 p2 len chord)
  (setq   lst   (entget ent)
          cen   (cdr (assoc 10 lst))        ; center point
          rad   (cdr (assoc 40 lst))        ; radius
          ang1  (cdr (assoc 50 lst))        ; start angle
          ang2  (cdr (assoc 51 lst))        ; end angle
          inc   (- ang1 ang2)               ; included angle
          inc   (if (minusp inc) (- inc) (- (* pi 2.0) inc)) ; included angle correction
          p1    (polar cen ang1 rad)        ; start point
          p2    (polar cen ang2 rad)        ; end point
          len   (* (/ inc (* 2 pi))        ; arc length: (included angle / 360) * circumference
                  (* 2 (* pi rad))
            ;;  another arc length (abs (* (- ang1 ang2) ra))
          chord (distance p1 p2)           ; chord length
  (list p1 p2 len chord)
;;;Arguments
;;;The entity name of an arc
;;;Example
;;;(arc-info (car (entsel)))
« Reply #6 on: July 09, 2007, 11:13:09 AM »
CAB,
These properties exist in 2008:
Select Entity to Display it's Data: ; IAcadArc: AutoCAD Arc Interface
; Property values:
;   Application (RO) = #<VLA-OBJECT IAcadApplication 00d73d3c>
;   ArcLength (RO) = 5.70731
;   Area (RO) = 4.85198
;   Center = (6.80792 2.02792 0.0)
;   Document (RO) = #<VLA-OBJECT IAcadDocument 01b75558>
;   EndAngle = 2.9975
;   EndPoint (RO) = (4.42674 2.37342 0.0)
;   Handle (RO) = "123"
;   HasExtensionDictionary (RO) = 0
;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 065f72ec>
;   Layer = "0"
;   Linetype = "ByLayer"
;   LinetypeScale = 1.0
;   Lineweight = -1
;   Material = "ByLayer"
;   Normal = (0.0 0.0 1.0)
;   ObjectID (RO) = 2130392472
;   ObjectName (RO) = "AcDbArc"
;   OwnerID (RO) = 2130386200
;   PlotStyleName = "ByLayer"
;   Radius = 2.40611
;   StartAngle = 0.6255
;   StartPoint (RO) = (8.75848 3.43671 0.0)
;   Thickness = 0.0
;   TotalAngle (RO) = 2.37201
;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 06589ed8>
;   Visible = -1
Ron
« Reply #7 on: July 09, 2007, 11:41:59 AM »
Thanks Ron,
I see that they are Read Only, so they are calculated for you. Therefore you can't change the Arc using them. You will need to calculate the new start & end angles and update those properties. Right?
« Reply #8 on: July 09, 2007, 11:52:14 AM »
That is correct :)
rainier
« Reply #9 on: July 09, 2007, 06:21:11 PM »
thanks guys,
i need a lisp routine code for changing the arc's coordinated or lisp formula to change the assoc like:
maybe the radius value will still remain at ease, but the center point, start or end angles will be change...
any idea to change it mathematically??  here is my sample.. attach.
please help... thanks
« Last Edit: July 09, 2007, 06:22:34 PM by rainier »
« Reply #10 on: July 09, 2007, 06:30:53 PM »
Could you not just use fillet?
rainier
« Reply #11 on: July 09, 2007, 07:01:00 PM »
the sequence i draw was line to arc to line, what if i have a line to arc to arc or arc to arc to arc... in that sequence i cant make a fillet on it...
is there other mathematical computation... to change the coordinates....  :-(
please help.. thanks..
rainier
« Reply #12 on: July 09, 2007, 10:16:04 PM »
guys, help me...
maybe there is a solution on the changing the coordinated... mathematically or logically...
or maybe Lisp routine can solve this problem...
how about stretch command...
how to use stretch with out using window select but its points... to change its coordinates...??
please help...
« Last Edit: July 09, 2007, 10:21:42 PM by rainier »
« Reply #13 on: July 09, 2007, 11:10:05 PM »
Have you tried simply changing the arc centerPoint and radius ?
rainier
« Reply #14 on: July 09, 2007, 11:18:17 PM »
yap! using entupd...
