Darn, thought I had that one correct.
Well thanks for showing me what I need to study up on you guys!
Oh I really like the second method you used there with min. Perfect example of how experience is key so I went and commented it, committing it to memory best I can
(defun sumsqr ( x y z / m) ;define
(setq m (min x y z)) ;sets a variable m to be equal to the lowest of the three values
(cond ((= x m) (+ (* y y) (* z z))) ;checks if x is lowest, thereby qualifying y and z, add the sqrts
((= y m) (+ (* x x) (* z z))) ;checks if y is lowest, thereby qualifying x and z, add the sqrts
((+ (* x x) (* y y))) ;otherwise z must be lowest therefor x and y are qualified, add the sqrts
) ;cond
) ;defun
