Code Red => AutoLISP (Vanilla / Visual) => Topic started by: One Shot on April 21, 2005, 09:10:04 PM
Please look at this lisp to tell me if this will load automatically. If I did not do this correctly. Please tell me what I did wrong and how to fix it.
Thank you,
Brad
Date Modified: 04/21/05
By Whom: Bcrouse
;; This will load the fixtextstyle.lsp file. This file must
;; be able to be found within your support directories.
(load "fixtextstyle.lsp")
;; This then runs the c:fx function as you have it defined
;; in the fixtextstyle.lsp file
(c:fx)
(defun C:fx ( / stylist txtstyle ss indx ent ent_alst str)
(setvar "cmdecho" 0)
(command "_.undo" "be")
(setq stylist '("NOTES" "DWGTITLES" "DWGTITLE" "HANDDWGTITLE" "HANDWGTITLE" "HANDWGTITLE" "RMNAMES"))
(while (/= stylist nil)
(setq txtstyle (car stylist))
(if (= (tblsearch "STYLE" txtstyle) nil)
(command "-style" txtstyle "simplex.shx" 0 0.7 0 "No" "No" "No")
(fixtxtstyle txtstyle)
(setq stylist (cdr stylist))
(setq ss (ssget "X" '((-4 . "<AND")(-4 . "<OR")(0 . "TEXT")(0 . "MTEXT")(-4 . "OR>")
(-4 . "<OR")(7 . "NOTES")(7 . "DWGTITLES")(7 . "DWGTITLE")(7 . "HANDWGTITLE")
(7 . "HANDDWGTITLEs")(7 . "HANDWGTITLEs")(7 . "RMNAMES")
(-4 . "OR>")(-4 . "AND>"))))
(setq indx 0)
(while (<= indx (- (sslength ss) 1))
(setq ent (ssname ss indx))
(setq ent_alst (entget ent))
((= (cdr (assoc 0 ent_alst)) "TEXT")
(setq ent_alst (subst (cons 41 0.7) (assoc 41 ent_alst) ent_alst))
((= (cdr (assoc 0 ent_alst)) "MTEXT")
(setq str (cdr (assoc 1 ent_alst)))
(if (/= (vl-string-position (ascii ";") str) nil)
(setq str (strcat "{" (substr str (+ (vl-string-position (ascii ";") str) 2))))
(setq ent_alst (subst (cons 1 str) (assoc 1 ent_alst) ent_alst))
(entmod ent_alst)
(entupd ent)
(setq indx (1+ indx))
(command "_.regen")
(command "_.undo" "end")
(setvar "textstyle" "NOTES")
(setvar "cmdecho" 1)
(defun fixtxtstyle (txtsty / txtsty)
(setq txtsty (entget (tblobjname "STYLE" txtsty)))
(setq txtsty (subst (cons 41 0.7) (assoc 41 txtsty) txtsty))
(setq txtsty (subst (cons 3 "simplex.shx") (assoc 3 txtsty) txtsty))
(entmod txtsty)
To autoload/run you must remove the first two lisp lines and place them into your acaddoc.lsp:
(c:fx)
Note that these two get the same selection set.
(setq ss (ssget "X" '((0 . "TEXT,MTEXT")
(7 . "NOTES,DWGTITLES,DWGTITLE,HANDWGTITLE,HANDDWGTITLEs,HANDWGTITLEs,RMNAMES"))))
Here is my AcadDoc.lsp with the load for the
; Next available MSG number is 104
; MODULE_ID ACAD2005doc_LSP_
;;; ACAD2005DOC.LSP Version 1.0 for AutoCAD 2005
;;; Copyright (C) 1994 - 2003 by Autodesk, Inc.
;;; Permission to use, copy, modify, and distribute this software
;;; for any purpose and without fee is hereby granted, provided
;;; that the above copyright notice appears in all copies and
;;; that both that copyright notice and the limited warranty and
;;; restricted rights notice below appear in all supporting
;;; documentation.
;;; AUTODESK PROVIDES THIS PROGRAM "AS IS" AND WITH ALL FAULTS.
;;; AUTODESK SPECIFICALLY DISCLAIMS ANY IMPLIED WARRANTY OF
;;; MERCHANTABILITY OR FITNESS FOR A PARTICULAR USE. AUTODESK, INC.
;;; DOES NOT WARRANT THAT THE OPERATION OF THE PROGRAM WILL BE
;;; UNINTERRUPTED OR ERROR FREE.
;;; Use, duplication, or disclosure by the U.S. Government is subject to
;;; restrictions set forth in FAR 52.227-19 (Commercial Computer
;;; Software - Restricted Rights) and DFAR 252.227-7013(c)(1)(ii)
;;; (Rights in Technical Data and Computer Software), as applicable.
;;; Note:
;;; This file is loaded automatically by AutoCAD every time
;;; a drawing is opened. It establishes an autoloader and
;;; other utility functions.
;;; Globalization Note:
;;; We do not support autoloading applications by the native
;;; language command call (e.g. with the leading underscore
;;; mechanism.)
;;;===== Raster Image Support for Clipboard Paste Special =====
;; IMAGEFILE
;; Allow the IMAGE command to accept an image file name without
;; presenting the file dialog, even if filedia is on.
;; Example: (imagefile "c:/images/house.bmp")
(defun imagefile (filename / filedia-save cmdecho-save)
(setq filedia-save (getvar "FILEDIA"))
(setq cmdecho-save (getvar "CMDECHO"))
(setvar "FILEDIA" 0)
(setvar "CMDECHO" 0)
(command "_.-image" "_attach" filename)
(setvar "FILEDIA" filedia-save)
(setvar "CMDECHO" cmdecho-save)
;;;=== General Utility Functions ===
; R12 compatibility - In R12 (acad_helpdlg) was an externally-defined
; ADS function. Now it's a simple AutoLISP function that calls the
; built-in function (help). It's only purpose is R12 compatibility.
; If you are calling it for anything else, you should almost certainly
; be calling (help) instead.
(defun acad_helpdlg (helpfile topic)
(help helpfile topic)
(defun *merr* (msg)
(setq *error* m:err m:err nil)
(defun *merrmsg* (msg)
(princ msg)
;; Loads the indicated ARX app if it isn't already loaded
;; returns nil if no load was necessary, else returns the
;; app name if a load occurred.
(defun verify_arxapp_loaded (app)
(if (not (loadedp app (arx)))
(arxload app f)
;; determines if a given application is loaded...
;; general purpose: can ostensibly be used for appsets (arx) or (ads) or....
;; app is the filename of the application to check (extension is required)
;; appset is a list of applications, (such as (arx) or (ads)
;; returns T or nil, depending on whether app is present in the appset
;; indicated. Case is ignored in comparison, so "foo.arx" matches "FOO.ARX"
;; Also, if appset contains members that contain paths, app will right-match
;; against these members, so "bar.arx" matches "c:\\path\\bar.arx"; note that
;; "bar.arx" will *not* match "c:\\path\\foobar.arx."
(defun loadedp (app appset)
(cond (appset (or
;; exactly equal? (ignoring case)
(= (strcase (car appset))
(strcase app))
;; right-matching? (ignoring case, but assuming that
;; it's a complete filename (with a backslash before it)
(and
(> (strlen (car appset)) (strlen app))
(= (strcase (substr (car appset)
(- (strlen (car appset))
(strlen app)
(strcase (strcat "\\" app))
;; no match for this entry in appset, try next one....
(loadedp app (cdr appset)) )))
;;; ===== Single-line MText editor =====
(defun LispEd (contents / fname dcl state)
(if (not (setq fname (getvar "program")))
(setq fname "acad")
(strcat fname ".dcl")
(setq dcl (load_dialog fname))
(if (not (new_dialog "LispEd" dcl)) (exit))
(set_tile "contents" contents)
(mode_tile "contents" 2)
(action_tile "contents" "(setq contents $value)")
(action_tile "accept" "(done_dialog 1)")
(action_tile "mtexted" "(done_dialog 2)" )
(setq state (start_dialog))
(unload_dialog dcl)
((= state 1) contents)
((= state 2) -1)
(t 0)
;;; ===== Discontinued commands =====
(defun c:ddselect(/ cmdecho-save)
(command "._+options" 7)
(defun c:ddgrips(/ cmdecho-save)
(defun c:gifin ()
(alert "\nThe GIFIN command is no longer supported.\nUse the IMAGE command to attach raster image files.\n")
(defun c:pcxin ()
(alert "\nThe PCXIN command is no longer supported.\nUse the IMAGE command to attach raster image files.\n")
(defun c:tiffin ()
(alert "\nThe TIFFIN command is no longer supported.\nUse the IMAGE command to attach raster image files.\n")
(defun c:ddemodes()
(alert "The Object Properties toolbar incorporates DDEMODES functionality. \nDDEMODES has been discontinued. \n\nFor more information, select \"Object Properties toolbar\" from the AutoCAD Help Index tab.")
(defun c:ddrmodes(/ cmdecho-save)
(command "._+dsettings" 0)
;;; ===== AutoLoad =====
;;; Check list of loaded <apptype> applications ("ads" or "arx")
;;; for the name of a certain appplication <appname>.
;;; Returns T if <appname> is loaded.
(defun ai_AppLoaded (appname apptype)
(apply 'or
(mapcar
'(lambda (j)
(wcmatch
(strcase j T)
(strcase (strcat "*" appname "*") T)
(eval (list (read apptype)))
;; Native Rx commands cannot be called with the "C:" syntax. They must
;; be called via (command). Therefore they require their own autoload
;; command.
(defun autonativeload (app cmdliste / qapp)
(setq qapp (strcat "\"" app "\""))
(setq initstring "\nInitializing...")
(mapcar
'(lambda (cmd / nom_cmd native_cmd)
(setq nom_cmd (strcat "C:" cmd))
(setq native_cmd (strcat "\"_" cmd "\""))
(if (not (eval (read nom_cmd)))
(eval
(read (strcat
"(defun " nom_cmd "()"
"(setq m:err *error* *error* *merrmsg*)"
"(if (ai_ffile " qapp ")"
"(progn (princ initstring)"
"(_autoarxload " qapp ") (command " native_cmd "))"
"(ai_nofile " qapp "))"
"(setq *error* m:err m:err nil))"
cmdliste)
nil
(defun _autoqload (quoi app cmdliste / qapp symnam)
(mapcar
'(lambda (cmd / nom_cmd)
(eval
(read (strcat
"(defun " nom_cmd "( / rtn)"
"(_auto" quoi "load " qapp ") (setq rtn (" nom_cmd ")))"
"(setq *error* m:err m:err nil)"
"rtn)"
cmdliste)
nil
(defun autoload (app cmdliste)
(_autoqload "" app cmdliste)
(defun autoarxload (app cmdliste)
(_autoqload "arx" app cmdliste)
(defun autoarxacedload (app cmdliste / qapp symnam)
(mapcar
(eval
(read (strcat
"(defun " nom_cmd "( / oldcmdecho)"
"(_autoarxload " qapp ")"
"(setq oldcmdecho (getvar \"CMDECHO\"))"
"(setvar \"CMDECHO\" 0)"
"(command " "\"_" cmd "\"" ")"
"(setvar \"CMDECHO\" oldcmdecho))"
"(princ))"
cmdliste)
nil
(defun _autoload (app)
; (princ "Auto:(load ") (princ app) (princ ")") (terpri)
(load app)
(defun _autoarxload (app)
; (princ "Auto:(arxload ") (princ app) (princ ")") (terpri)
(arxload app)
(defun ai_ffile (app)
(or (findfile (strcat app ".lsp"))
(findfile (strcat app ".exp"))
(findfile (strcat app ".exe"))
(findfile (strcat app ".arx"))
(findfile app)
(defun ai_nofile (filename)
(princ
(strcat "\nThe file "
filename
"(.lsp/.exe/.arx) was not found in your search path folders."
(princ "\nCheck the installation of the support files and try again.")
;;;===== AutoLoad LISP Applications =====
; Set help for those apps with a command line interface
(autoload "edge" '("edge"))
(setfunhelp "C:edge" "" "edge")
(autoload "3d" '("3d" "3d" "ai_box" "ai_pyramid" "ai_wedge" "ai_dome"
"ai_mesh" "ai_sphere" "ai_cone" "ai_torus" "ai_dish")
(setfunhelp "C:3d" "" "3d")
(setfunhelp "C:ai_box" "" "3d_box")
(setfunhelp "C:ai_pyramid" "" "3d_pyramid")
(setfunhelp "C:ai__wedge" "" "3d_wedge")
(setfunhelp "C:ai_dome" "" "3d_dome")
(setfunhelp "C:ai_mesh" "" "3d_mesh")
(setfunhelp "C:ai_sphere" "" "3d_sphere")
(setfunhelp "C:ai_cone" "" "3d_cone")
(setfunhelp "C:ai_torus" "" "3d_torus")
(setfunhelp "C:ai_dish" "" "3d_dish")
(autoload "3darray" '("3darray"))
(setfunhelp "C:3darray" "" "3darray")
(autoload "mvsetup" '("mvsetup"))
(setfunhelp "C:mvsetup" "" "mvsetup")
(autoload "attredef" '("attredef"))
(setfunhelp "C:attredef" "" "attredef")
(autoload "tutorial" '("tutdemo" "tutclear"
"tutdemo"
"tutclear"))
;;;===== AutoArxLoad Arx Applications =====
;;; ===== Double byte character handling functions =====
(defun is_lead_byte(code)
(setq asia_cd (getvar "dwgcodepage"))
( (or (= asia_cd "dos932")
(= asia_cd "ANSI_932")
(or (and (<= 129 code) (<= code 159))
(and (<= 224 code) (<= code 252))
( (or (= asia_cd "big5")
(= asia_cd "ANSI_950")
(and (<= 129 code) (<= code 254))
( (or (= asia_cd "gb2312")
(= asia_cd "ANSI_936")
(and (<= 161 code) (<= code 254))
( (or (= asia_cd "johab")
(= asia_cd "ANSI_1361")
(and (<= 132 code) (<= code 211))
( (or (= asia_cd "ksc5601")
(= asia_cd "ANSI_949")
;;; FITSTR2LEN
;;; Truncates the given string to the given length.
;;; This function should be used to fit symbol table names, that
;;; may turn into \U+ sequences into a given size to be displayed
;;; inside a dialog box.
;;; Ex: the following string:
;;; "This is a long string that will not fit into a 32 character static text box."
;;; would display as a 32 character long string as follows:
;;; "This is a long...tatic text box."
(defun fitstr2len (str1 maxlen)
;;; initialize internals
(setq tmpstr str1)
(setq len (strlen tmpstr))
(if (> len maxlen)
(setq maxlen2 (/ maxlen 2))
(if (> maxlen (* maxlen2 2))
(setq maxlen2 (- maxlen2 1))
(if (is_lead_byte (substr tmpstr (- maxlen2 2) 1))
(setq tmpstr1 (substr tmpstr 1 (- maxlen2 3)))
(setq tmpstr1 (substr tmpstr 1 (- maxlen2 2)))
(if (is_lead_byte (substr tmpstr (- len (- maxlen2 1)) 1))
(setq tmpstr2 (substr tmpstr (- len (- maxlen2 3))))
(setq tmpstr2 (substr tmpstr (- len (- maxlen2 2))))
(setq str2 (strcat tmpstr1 "..." tmpstr2))
) ;;; progn
(setq str2 (strcat tmpstr))
) ;;; if
) ;;; defun
;;; If the first object in a selection set has an attached URL
;;; Then launch browser and point to the URL.
;;; Called by the Grips Cursor Menu
(defun C:gotourl ( / ssurl url i)
(setq m:err *error* *error* *merrmsg* i 0)
; if some objects are not already pickfirst selected,
; then allow objects to be selected
(if (not (setq ssurl (ssget "_I")))
(setq ssurl (ssget))
; if geturl LISP command not found then load arx application
(if (/= (type geturl) 'EXRXSUBR)
(arxload "achlnkui")
; Search list for first object with an URL
(while (and (= url nil) (< i (sslength ssurl)))
(setq url (geturl (ssname ssurl i))
i (1+ i))
; If an URL has be found, open browser and point to URL
(if (= url nil)
(alert "No Universal Resource Locator associated with the object.")
(command "_.browser" url)
;; Used by the import dialog to silently load a 3ds file
(defun import3ds (filename / filedia_old render)
;; Load Render if not loaded
(setq render (findfile "acRender.arx"))
(if render
(verify_arxapp_loaded render)
(quit)
;; Save current filedia & cmdecho setting.
;; Call 3DSIN and pass in filename.
(c:3dsin 1 filename)
;; Reset filedia & cmdecho
; New "Select All" function. Cannot be called transparently.
(defun c:ai_selall ( / ss old_error a b old_cmd old_hlt)
(setq a "CMDECHO" b "HIGHLIGHT"
old_cmd (getvar a) old_hlt (getvar b)
old_error *error* *error* ai_error)
(if (ai_notrans)
(princ "Selecting objects...")
(setvar a 0)
(setvar b 0)
(command "_.SELECT" "_ALL" "") ; Create Previous SS
(setvar a old_cmd)
(setvar b old_hlt)
(setq ss (ssget "_P"))
(sssetfirst ss ss) ; Non-gripped, but selected (someday!)
(princ "done.\n")
(setq *error* old_error old_error nil ss nil)
;;; Routines that check CMDACTIVE and post an alert if the calling routine
;;; should not be called in the current CMDACTIVE state. The calling
;;; routine calls (ai_trans) if it can be called transparently or
;;; (ai_notrans) if it cannot.
;;; 1 - Ordinary command active.
;;; 2 - Ordinary and transparent command active.
;;; 4 - Script file active.
;;; 8 - Dialogue box active.
(defun ai_trans ()
(if (zerop (logand (getvar "cmdactive") (+ 2 8) ))
T
(alert "This command may not be invoked transparently.")
nil
(defun ai_transd ()
(if (zerop (logand (getvar "cmdactive") (+ 2) ))
T
nil
(defun ai_notrans ()
(if (zerop (logand (getvar "cmdactive") (+ 1 2 8) ))
T
nil
; New function for invoking the product support help through the browser
(defun C:ai_product_support ()
(setq url "http://www.autodesk.com/autocad-support")
(defun C:ai_product_support_safe ()
(setq 404page "WSProdSupp404.htm")
(command "_.browser2" 404page url)
(defun C:ai_training_safe ()
(setq url "http://www.autodesk.com/autocad-training")
(setq 404page "WSTraining404.htm")
(defun C:ai_custom_safe ()
(setq url "http://www.autodesk.com/developautocad")
(setq 404page "WSCustom404.htm")
;; Silent load.
Date Modified: 04/22/05
By Whom: Bcrouse
(c:fx)
I have add this to the end of this lisp. But it still will not load. Any help please?
(c:fx)
Lets try the obvious first: is fixtextstyle.lsp in the search path?
Lets try the obviouse first: is fixtextstyle.lsp in the search path?
Yes, it lives in the same search path.
if you type (load "fixtextstyle.lsp") at the command line, does it load?
This is from Autodesks website:
acad2000doc.lsp
Do not modify the reserved file acad2000doc.lsp; it contains AutoLISP?defined functions required by AutoCAD. The file acad2000doc.lsp is loaded into memory immediately before acaddoc.lsp.
Per this, I think you want an ACADDOC.LSP file, and remove the changes you made to the ACAD2005DOC.lsp file. If you dont have an ACADDOC file, create one. That should fix your problem
Done. I removed it.
Did it work?
Did it work?
Could I create another ACADDOC file and name it ACADDOC1.lsp?
yes, but wait! The code you posted made a reference to the Acad2005Doc.lsp in the comments. Did you rename that file to Acaddoc.lsp? Do you still have the Acad2005doc.lsp file?
I uploaded my copy of the file here (http://www.theswamp.org/lilly_pond/cmdrduh/acad2005doc.lsp?nossi=1). Just in case....
I made a copy of the Acad2005Doc.lsp so I can replace it very easily.
Thank you,
So now you have the 2005doc back, do you need to create an Acaddoc.lsp?
I created this (http://www.theswamp.org/lilly_pond/cmdrduh/acaddoc.lsp?nossi=1) if you need it
I did a save as of my presnet Acaddoc.lsp and named it Acaddoc1.lsp. Please look at this Acaddoc1.lsp and tell if I did it correctly. If not, please show me how to properly create one.
;; ACADDOC1.LSP
;; ACADDOC1.LSP ver. 2005
;; B.N. Crouse
;; 04/22/05
;; FUNCTION Defuns
(c:fx)
As far as i know, that will work. I posted a version of acaddoc.lsp which defined FX and ran it.
Not that you need to do that, I was just trying to help. What I do see is this: In your existing acaddoc.lsp, you will need to (load "acaddoc1.lsp")
ANY GURUs watching this PLEASE correct me if im wrong here
CmdrDuh,
Thank you for your help. It is working now.
Thank you,
Brad
Glad its working
I am running into a problem with this lisp. What I am trying to is to have 2 Text styles changed from simplex.shx to swiss721 BT. If you look at the lisp @ defun c:fx1. This is where I would like to have it change. Can some please point me in the right direction?
Thank you for all your help.
By Whom: Bcrouse
(setq stylist '("NOTES" "DWGTITLES" "DWGTITLE" "HANDDWGTITLE" "HANDWGTITLES" "HANDWGTITLE" "RMNAMES"))
(setq indx 0)
(if (/= ss nil)
(entmod ent_alst)
(entupd ent)
(command "_.regen")
(entmod txtsty)
(defun C:fx1 ( / stylist txtstyle ss indx ent ent_alst str)
(setq stylist '("DWGTITLES" "RMNAMES"))
(command "-style" txtstyle "Swis721 BT.shx" 0 0.7 0 "No" "No" "No")
(7 . "DWGTITLES,RMNAMES"))))
(setq indx 0)
(if (/= ss nil)
(entmod ent_alst)
(entupd ent)
(command "_.regen")
(setvar "textstyle" "DWGTITLES")
(setq txtsty (subst (cons 3 "Swis721 BT.shx") (assoc 3 txtsty) txtsty))
(entmod txtsty)
Try This.
;;; Date Modified: 04/22/05
;;; By Whom: Bcrouse
(defun C:fx ( / stylist txtstyle ss indx ent ent_alst str fixtxtstyle)
(defun fixtxtstyle (txtsty)
(entmod txtsty)
(setq indx 0)
(if (/= ss nil)
(entmod ent_alst)
(entupd ent)
(command "_.regen")
(defun C:fx1 ( / stylist txtstyle ss indx ent ent_alst str fixtxtstyle)
(defun fixtxtstyle (txtsty )
(entmod txtsty)
(setq indx 0)
(if (/= ss nil)
(entmod ent_alst)
(entupd ent)
(command "_.regen")
I need to add the Text Style before I do a text style merge. I would like to add this to the lisp that is associated with this thread. How would I go about doing this. I know that I need to ensure that the font sylte is found. But I don't know how to do that. Can someone please point me in the right direct?
(command "-style" "DWGTITLES" "swis721 BT.shx" 1.20 0 "No" "No" "No")
