Author Topic: Extract data from HTML-tables  (Read 1573 times)
Peter2
« on: July 25, 2017, 04:19:53 AM »
Maybe I have to read data from HTML-tables. :embarrassed:
Any advices for solutions / workarounds / code-snippets are appreciated  :-)
Peter
BricsCAD V23
Re: Extract data from HTML-tables
« Reply #1 on: July 25, 2017, 06:17:41 AM »
html is just xml if it's done properly (i.e. all tags are closed) so if you can use a COM xml lib or there's one for AutoLisp just use that to 'scrape' the data out. Hopefully the table will have an 'id' or 'class' attribute to make selecting the table nodes a bit easier.
hth
- John Carmack
- J.R.R. Tolkien
Peter2
« Reply #2 on: July 25, 2017, 07:51:52 AM »
...a COM xml lib or there's one for AutoLisp just use that ...
Can you / somebody recommend a special software?
Peter
BricsCAD V23
« Reply #3 on: July 25, 2017, 07:59:47 AM »
« Reply #4 on: July 25, 2017, 06:46:55 PM »
Once you get something going you might want to use an XPath to zero in on your elements, sing out if you need a hand with the XPath query, will just need a sample to work with.
- John Carmack
- J.R.R. Tolkien
dgorsman
« Reply #5 on: July 26, 2017, 10:13:56 AM »
When I generate HTML reports, I usually provide the option to write XML as well (fairly simple, as the former is derived from the latter).  That way if the raw data is required it's more easily accessed.
But if you aren't generating the HTML yourself, pray that it's well formed.  You can MSXML6 in LISP to read it as XML.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
      {MasterBasics;}
Peter2
« Reply #6 on: July 27, 2017, 03:10:55 AM »
Thanks to all.
At the moment it seems that I can avoid the HTML-extract, but I will keep (I will try to ...) the infos in mind for the next time.
Peter
BricsCAD V23
