Author Topic: Find the nest level of a list  (Read 7306 times)
Marc'Antonio Alessi
  • Marco
Re: Find the nest level of a list
« Reply #15 on: October 20, 2017, 03:38:30 AM »
The only easy iterative approach that comes to my mind is this:
IMO converting the whole list to a string and then processing is more frustrating. :)
Yes but it is not so bad:
(setq alist '(((((("A")))((((((((((((((((((((((("B" ("C"))))))))))))))))))))))))("C")))) )
Benchmark.lsp | © 2005 Michael Puckett | All Rights Reserved
Elapsed milliseconds / relative speed for 32768 iteration(s):
    (LEEFOO2 ALIST)...................1375 / 3.89 <fastest>
    (ALE_LIST_NESTEDLEVEL2 ALIST).....2391 / 2.23
    (NESTLVL ALIST)...................5343 / 1 <slowest>
Thanks for the benchmark Ron - I suspected that Lee's second suggestion would be the fastest.
The recursion to Lee's levels is not in my reach, it's really on another planet for me  :oops: :'( (and for many others too)  ::)
Grrr1337
« Reply #16 on: October 20, 2017, 04:42:10 AM »
Yeah Alessi - iterating a string makes sence to be faster.
This is my attempt with it - which ended up a bit more understandable version of Lee's 3rd code (the RJP-Style) :
  1. (defun nlvls ( L / sL n x isStr nL r )
  2.   (and L (listp L) (setq sL (mapcar 'chr (vl-string->list (vl-prin1-to-string L))))
  3.     (progn (setq n -1)
  4.       (while sL (setq x (car sL)) (setq sL (cdr sL))
  5.         (cond
  6.           ( (and (= "(" x) (not isStr) )
  7.             (setq n (1+ n))
  8.           )
  9.           ( (and (= ")" x) (not isStr) )
  10.             (setq n (1- n))
  11.           )
  12.           ( (= "\"" x) (setq isStr (if isStr nil T)) ) ; shift the string state
  13.         ); cond
  14.         (setq nL (cons n nL))
  15.       ); while
  16.       (setq r (apply 'max nL))
  17.     ); progn
  18.   ); and
  19.   r
  20. ); defun nlvls
  1. _$ (nlvls "string") -> nil
  2. _$ (nlvls nil ) -> nil
  3. _$ (nlvls '("A" "B" "C") ) -> 0
  4. _$ (nlvls '(("A")("B")("C")) ) -> 1
  5. _$ (nlvls '(("A")(("B"))("C")) ) -> 2
  6. _$ (nlvls '(("A")((((("B")))))("C")) ) -> 5
  7. _$ (nlvls '(((("A")))((((((("B")))))))("C")) ) -> 7
  8. _$ (nlvls '(((("A")))((((((((((((((((((((((("B" ("C"))))))))))))))))))))))))("C")) ) -> 24
  9. _$ (nlvls '(((((("A")))((((((((((((((((((((((("B" ("C"))))))))))))))))))))))))("C")))) ) -> 26
  10. _$ (nlvls '(("(1") "2" "3")) -> 1
  11. _$ (nlvls '(((1) (2) (3)))) -> 2
And sorry I'm not that good string manipulator. :)
(apply ''((a b c)(a b c))
vevo.bg
Marc'Antonio Alessi
  • Marco
« Reply #17 on: October 20, 2017, 05:02:14 AM »
(setq alist '(((((("A")))((((((((((((((((((((((("B" ("C"))))))))))))))))))))))))("C")))) ); -> 26
My version works only on one long string:
Comando: (vl-princ-to-string alist)
"((((((A))) (((((((((((((((((((((((B (C)))))))))))))))))))))))) (C))))"
Not with a list of strings:
Comando: (mapcar 'chr (vl-string->list (vl-prin1-to-string alist)))
("(" "(" "(" "(" "(" "(" "\"" "A" "\"" ")" ")" ")" " " "(" "(" "(" "(" "(" "(" "(" "(" "(" "(" "(" "(" "(" "(" "(" "(" "(" "(" "(" "(" "(" "(" "(" "\"" "B" "\"" " " "(" "\"" "C" "\"" ")" ")" ")" ")" ")" ")" ")" ")" ")" ")" ")" ")" ")" ")" ")" ")" ")" ")" ")" ")" ")" ")" ")" ")" " " "(" "\"" "C" "\"" ")" ")" ")" ")")
    (LEEFOORJPSTYLE ALIST)............1547 / 1.88 <fastest>
    (ALE_LIST_NESTEDLEVEL2 ALIST).....2406 / 1.21
    (NLVLS ALIST).....................2907 / 1 <slowest>
I think that a good solution (not recursive) is to modifiy Lee's LEEFOORJPSTYLE
(defun LEEFOORJPSTYLE ( l / n r x )
    (setq l (vl-string->list (vl-prin1-to-string l)) r 0 n -1)
    (while (setq x (car l))
            (   (= 34 x) (setq l (member 34 (cdr l))))
            (   (= 40 x) (setq n (1+ n)))
            (   (= 41 x) (setq r (max n r) n (1- n)))
        (setq l (cdr l))
    r
to skip numbers as it skip strings... ;)
Marc'Antonio Alessi
  • Marco
« Reply #18 on: October 20, 2017, 05:11:52 AM »
This is a test with Strings and Numbers;
(setq alist '((((((1212121212 12121212 12121212 1 233333333)))((((((((((((((((((((((("BBBBBBBB" (121233333 211212 121212 12121212 12121212 12121212 1233333312))))))))))))))))))))))))("CBBBBBBB")))))
Elapsed milliseconds / relative speed for 16384 iteration(s):
    (ALE_LIST_NESTEDLEVEL2 ALIST).....1391 / 2.34 <fastest>
    (LEEFOORJPSTYLE ALIST)............1515 / 2.15
    (NLVLS ALIST).....................3250 / 1 <slowest>
VovKa
  • Ukraine
« Reply #19 on: October 20, 2017, 05:16:41 AM »
'("a\"(((())))")
Grrr1337
« Reply #20 on: October 20, 2017, 05:48:59 AM »
Yeah, I noticed that.. thats why I apologise. :)
'("a\"(((())))")
Blew my head.  :-o
I guess this shows that processing the whole list as a string would be even more complex.
vevo.bg
Marc'Antonio Alessi
  • Marco
« Reply #21 on: October 20, 2017, 05:55:31 AM »
'("a\"(((())))")
Comando: (ALE_List_NestedLevel2  '("a\"(((())))"))
4
Comando: (LEEFOORJPSTYLE  '("a\"(((())))"))
4
Comando: (nlvls  '("a\"(((())))"))
4
Comando: (foo  '("a\"(((())))"))
0
Yes... Lee's Foo is the best,  8)
Grrr1337
« Reply #22 on: October 20, 2017, 06:12:47 AM »
Alessi,
The codes on replies #1 #5 #13 aswell the first one in my post should work on this (since they don't process the list as a string).
This mod of the code in my main post should be slightly faster:
  1. ; _$ (NestedListLevel "string") -> nil
  2. ; _$ (NestedListLevel nil ) -> nil
  3. ; _$ (NestedListLevel '("A" "B" "C") ) -> 0
  4. ; _$ (NestedListLevel '(("A")("B")("C")) ) -> 1
  5. ; _$ (NestedListLevel '(("A")(("B"))("C")) ) -> 2
  6. ; _$ (NestedListLevel '(("A")((((("B")))))("C")) ) -> 5
  7. ; _$ (NestedListLevel '(((("A")))((((((("B")))))))("C")) ) -> 7
  8. ; _$ (NestedListLevel '(((("A")))((((((((((((((((((((((("B" ("C"))))))))))))))))))))))))("C")) ) -> 24
  9. ; _$ (NestedListLevel '(((((("A")))((((((((((((((((((((((("B" ("C"))))))))))))))))))))))))("C")))) ) -> 26
  10. ; _$ (NestedListLevel '(("(1") "2" "3")) -> 1
  11. ; _$ (NestedListLevel '(((1) (2) (3)))) -> 2
  12. ; _$ (NestedListLevel '("a\"(((())))")) -> 0
  13. (defun NestedListLevel ( L / rec )
  14.   (defun rec ( L i )
  15.     (cond
  16.       ( (not L) (list i))
  17.       ( (eq 'LIST (type L))
  18.         (cond
  19.           ( (eq 'LIST (type (car L))) (append (rec (car L) (1+ i)) (rec (cdr L) i)) )
  20.           ( (rec (cdr L) i) )
  21.         )
  22.       )
  23.     )
  24.   )
  25.   (if (and L (listp L)) (apply 'max (rec L 0)) )
  26. ); defun NestedListLevel
I assume that Lee's code in Reply #5 is the fastest, but I'm not sure how it compares to the one in Reply #13.
Theoretically the strategy you mentioned would be the fastest, until Vovka pointed out the nested strings problem.
(Sorry not sure how to address you [Mark/Antonio/Alessi])
vevo.bg
VovKa
  • Ukraine
« Reply #23 on: October 20, 2017, 06:33:56 AM »
as to the code in Reply #13
(NestLvl '((1 . 2)))
Grrr1337
« Reply #24 on: October 20, 2017, 07:46:30 AM »
Unexpected! <duh> :)
vevo.bg
Marc'Antonio Alessi
  • Marco
« Reply #25 on: October 20, 2017, 07:49:37 AM »
Alessi,
For #13 see #23...
(setq alist '((((((1212121212 12121212 12121212 1 233333333)((1 . 2)))("a\"(((())))")))((((((((((((((((((((((("BBBBBBBB" (121233333 211212 121212 12121212 12121212 12121212 1233333312))))))))))))))))))))))))("CBBBBBBB"))))
    (FOO#5 ALIST)..................1750 / 1.76 <fastest>
    (FOO#1 ALIST)..................1891 / 1.63
    (NESTEDLISTLEVEL#22 ALIST).....3078 / 1 <slowest>
>>> Marco
Grrr1337
« Reply #26 on: October 20, 2017, 08:31:49 AM »
I thought that #22 would be close to #5, but it seems that append and maybe (apply 'max ...) slows down the process.
Thanks Marco!
vevo.bg
VovKa
  • Ukraine
« Reply #27 on: October 20, 2017, 10:08:09 AM »
found one in a book https://issuu.com/enelf/docs/lisp1/382
section 3.3 number 2
it's a bit different but looks good
Grrr1337
« Reply #28 on: October 20, 2017, 11:21:24 AM »
Cool book!
However the function you pointed doesn't work:
; глубина = depth
(defun depth (х)
    ( (atom x) 1)
    (t (max_ (+ 1 (depth (car x))) (depth (cdr x))) )
(defun max_ (х у) ; встроенная функция MAX
  (if (> x y) x y)
Returns a value of 1 for all of our performed tests.
vevo.bg
Marc'Antonio Alessi
  • Marco
« Reply #29 on: October 20, 2017, 11:38:54 AM »
(defun depth (x)
    ( (atom x) 1)
(defun max_ (x y)
  (if (> x y) x y)
Comando: (setq alist '((((((1212121212 12121212 12121212 1 233333333)((1 . 2)))("a\"(((())))")))((((((((((((((((((((((("BBBBBBBB" (121233333 211212 121212 12121212 12121212 12121212 1233333312))))))))))))))))))))))))("CBBBBBBB"))))
((((((1212121212 12121212 12121212 1 233333333) ((1 . 2))) ("a\"(((())))"))) ((((((((((((((((((((((("BBBBBBBB" (121233333 211212 121212 12121212 12121212 12121212 1233333312)))))))))))))))))))))))) ("CBBBBBBB")))
Comando: (FOO#5 ALIST)
25
Comando: (depth AList)
27
Comando: (setq alist '(((((("A")))((((((((((((((((((((((("B" ("C"))))))))))))))))))))))))("C")))) )
(((((("A"))) ((((((((((((((((((((((("B" ("C")))))))))))))))))))))))) ("C"))))
26
28
