Author Topic: measure the width of the characters of a text and mtext  (Read 5392 times)
amc.dicsac
  • Autocad 2008
Re: measure the width of the characters of a text and mtext
« Reply #15 on: May 13, 2016, 07:06:41 PM »
<a href="http:/http://axprogramlisp.blogspot.pe" class="bbc_link" target="_blank">By Alexander Castro</a>
« Reply #16 on: May 14, 2016, 09:57:24 AM »
You can try this, but it does not work with mtext objects.  If it works for your dtext, then maybe you can change it to work with mtext.
It returns a list of two items.  You only need to worry about the first list, as that is the one that has the width per character.  You could use it like
(apply '+ (car (FontLetterWidth doc txObj)))
I do not have to time to play, but this is something I had already done.  Hope it is useful.
Code - Lisp: [Select]
  1. (defun FontLetterWidth (Doc TextObj / MdSpc StyCol Sty FontName DictCol DictObj cnt CurLtr tempText ll ur Dist FontWidthList
  2.                                       WidthList StyName String TextWd TextHt StyDictObj tempStrList tempList tempStr)
  3.     ; Returns a list of distances for the text string of the object supplied.  The distances are that of each
  4.     ;  letter in the string starting from the lower left bounding box point of the text, when the text is rotated
  5.     ;  to 0.0 degrees.
  6.     ; Idea from 'SomeCallMeDave' @ theswamp.  Thanks again.
  7.
  8.     (setq StyName (vla-get-StyleName TextObj))
  9.     (setq String (vlax-get TextObj (if (= (vla-get-ObjectName TextObj) "AcDbAttributeDefinition") "TagString" "TextString")))
  10.     (setq TextWd (vla-get-ScaleFactor TextObj))
  11.     (setq TextHt (vla-get-Height TextObj))
  12.     (setq TextLen (strlen String))
  13.     (setq cnt -1)
  14.     (while (setq cnt (vl-string-search "%%" String (setq cnt (1+ cnt))))
  15.         (setq tempStrList (cons (cons (1+ cnt) (setq tempStr (strcase (substr String (1+ cnt) 3)))) tempStrList))
  16.     )
  17.     (setq MdSpc (vla-get-ModelSpace Doc))
  18.     (setq StyCol (vla-get-TextStyles Doc))
  19.     (setq Sty (vla-Item StyCol StyName))
  20.     (setq FontName
  21.         (if (findfile (vla-get-fontFile Sty))
  22.             (vl-filename-base (vla-get-fontFile Sty))
  23.             (vl-filename-base (getvar "fontalt"))
  24.         )
  25.     )
  26.     ;(setq DictCol (vla-get-Dictionaries Doc))
  27.     ;(if (vl-catch-all-error-p (setq DictObj (vl-catch-all-apply 'vla-Item (list DictCol "MyFontWidthDict"))))
  28.     ;   (setq DictObj (vla-Add DictCol "MyFontWidthDict"))
  29.     ;)
  30.     ;(if (vl-catch-all-error-p (setq StyDictObj (vl-catch-all-apply 'vla-Item (list DictObj StyName))))
  31.     ;   (setq StyDictObj (vla-Add DictObj StyName))
  32.     ;)
  33.     (setq cnt 1)
  34.     (while (<= cnt TextLen)
  35.         (if (setq tempList (assoc cnt tempStrList))
  36.             (progn
  37.                 (setq CurLtr (cdr tempList))
  38.                 (setq cnt (+ cnt 2))
  39.             )
  40.             (setq CurLtr (substr String cnt 1))
  41.         )
  42.         (if (not (assoc CurLtr FontWidthList))
  43.             (progn
  44.                 (cond
  45.                     ((= CurLtr " ")
  46.                         (setq tempText (vlax-invoke MdSpc 'AddText "AA" '(0.0 0.0 0.0) 1.0))
  47.                         (vla-put-Height tempText 1.0)
  48.                         (vla-put-ScaleFactor tempText 1.0)
  49.                         (vlax-put tempText 'Normal '(0. 0. 1.))
  50.                         (vla-put-StyleName tempText StyName)
  51.                         (vla-GetBoundingBox tempText 'll 'ur)
  52.                         (setq ll (safearray-value ll))
  53.                         (setq ur (safearray-value ur))
  54.                         (setq Dist (distance (cons (car ll) (cdr ur)) ur))
  55.                         (vla-put-TextString tempText (strcat "A" CurLtr "A"))
  56.                         (vla-GetBoundingBox tempText 'll 'ur)
  57.                         (setq ll (safearray-value ll))
  58.                         (setq ur (safearray-value ur))
  59.                         (setq Dist (* TextWd (* TextHt (- (distance (cons (car ll) (cdr ur)) ur) Dist))))
  60.                         (setq FontWidthList (cons (cons CurLtr Dist) FontWidthList))
  61.                         (vla-Delete tempText)
  62.                     )
  63.                     ((and (equal cnt 3) (or (= CurLtr "%%U") (= CurLtr "%%O")))
  64.                         (setq tempText (vlax-invoke MdSpc 'AddText "A" '(0.0 0.0 0.0) 1.0))
  65.                         (vla-put-Height tempText 1.0)
  66.                         (vla-put-ScaleFactor tempText 1.0)
  67.                         (vlax-put tempText 'Normal '(0. 0. 1.))
  68.                         (vla-put-StyleName tempText StyName)
  69.                         (vla-GetBoundingBox tempText 'll 'ur)
  70.                         (setq ll (safearray-value ll))
  71.                         (setq ur (safearray-value ur))
  72.                         (setq tempPt (cons (car ll) (cdr ur)))
  73.                         (vla-put-TextString tempText (strcat CurLtr "A"))
  74.                         (vla-GetBoundingBox tempText 'll 'ur)
  75.                         (setq ll (safearray-value ll))
  76.                         (setq ur (safearray-value ur))
  77.                         (setq Dist (* TextWd (* TextHt (distance (cons (car ll) (cdr ur)) tempPt))))
  78.                         (setq FontWidthList (cons (cons CurLtr Dist) FontWidthList))
  79.                         (vla-Delete tempText)
  80.                     )
  81.                     (T
  82.                         (setq tempText (vlax-invoke MdSpc 'AddText CurLtr '(0.0 0.0 0.0) 1.0))
  83.                         (vla-put-Height tempText 1.0)
  84.                         (vla-put-ScaleFactor tempText 1.0)
  85.                         (vla-put-StyleName tempText StyName)
  86.                         (vlax-put tempText 'Normal '(0. 0. 1.))
  87.                         (vla-GetBoundingBox tempText 'll 'ur)
  88.                         (setq ll (safearray-value ll))
  89.                         (setq ur (safearray-value ur))
  90.                         (setq Dist (distance (cons (car ll) (cdr ur)) ur))
  91.                         (vla-put-TextString tempText (strcat CurLtr CurLtr))
  92.                         (vla-GetBoundingBox tempText 'll 'ur)
  93.                         (setq ll (safearray-value ll))
  94.                         (setq ur (safearray-value ur))
  95.                         (setq Dist (* TextWd (* TextHt (- (distance (cons (car ll) (cdr ur)) ur) Dist))))
  96.                         (setq FontWidthList (cons (cons CurLtr Dist) FontWidthList))
  97.                         (vla-Delete tempText)
  98.                     )
  99.                 )
  100.             )
  101.         )
  102.         (if (and (not (equal cnt 3)) (or (= CurLtr "%%U") (= CurLtr "%%O")))
  103.             (repeat 3
  104.                 (setq WidthList (cons 0.0 WidthList))
  105.             )
  106.             (if (equal (strlen CurLtr) 3)
  107.                 (repeat 3
  108.                     (setq WidthList (cons (/ (cdr (assoc CurLtr FontWidthList)) 3.0) WidthList))
  109.                 )
  110.                 (setq WidthList (cons (cdr (assoc CurLtr FontWidthList)) WidthList))
  111.             )
  112.         )
  113.         (setq cnt (1+ cnt))
  114.     )
  115.     ;(print FontWidthList)
  116.     (list (reverse WidthList) tempStrList)
  117. )
  118.
cmwade77
« Reply #17 on: May 19, 2016, 07:41:37 PM »
Based on your OP: Why not just use QLEADER to make your leaders?
Command: QLEADER
Specify first leader point, or [Settings] <Settings>: S
(see attached bitmap - set "underline bottom line")
Then - use Express Tools QLATTACH command
Command: _.qlattach
Select Leader:
Select Annotation:
Or you could use the mleader command with a custome style, we have similar leaders to this, but we don't do underlining, but it can do it.
PKENEWELL
« Reply #18 on: May 20, 2016, 09:41:05 AM »
Yes - that would work too. The reason I suggested QLEADER is because - out of the box - the Express Tool QLATTACH command works with Quick Leaders, but does not work with MLEADERS. I believe if the OP did a search for MTEXT to MLEADER however, there is probably some code already to do it with an MEADER:
Examples:
https://www.theswamp.org/index.php?topic=20228.msg245930#msg245930
https://www.theswamp.org/index.php?topic=43097.msg483158#msg483158
https://www.theswamp.org/index.php?topic=30319.msg359205#msg359205
« Last Edit: May 20, 2016, 09:49:17 AM by PKENEWELL »
"When you are asked if you can do a job, tell 'em, 'Certainly I can!' Then get busy and find out how to do it." - Theodore Roosevelt
cmwade77
« Reply #19 on: May 20, 2016, 05:38:11 PM »
Examples:
Yep and there are many more, including routines to convert qLeaders to mleaders. Including my code at:
https://www.theswamp.org/index.php?topic=46576.msg515804#msg515804
It does a pretty decent job at it too, but the text does need to be mText to work properly.
amc.dicsac
  • Autocad 2008
« Reply #20 on: May 25, 2016, 02:14:00 PM »
I'm sorry but I cannot understand you enough to help you or figure out what you are trying to do in your code. Perhaps some else here can understand what you are trying to do better.
Hi, here I have the program, that have developed people in the acadhispano forum, please tell me if it is possible to do the same but with mtext.
  1. ;;;;http://acadhispano.foroargentina.net/t34-ancho-mtext-y-text
  2. (defun c:seltl ( / text lead lt lp pf i)
  3. (if (and (setq text (entsel"\nSelect Text : "))
  4.  (setq lead (entsel"\nSelect leader : ")) )
  5.  (setq text (cdr(entget (car text)))
  6.  lt (textbox text)
  7.  lt (apply 'distance lt) ;; diagonal de la caja de texto
  8.  lead (entget (car lead))
  9.  lp (mapcar 'cdr (vl-remove-if '(lambda(a)(/=(car a) 10)) lead)) ;; puntos del leader
  10.  pf (polar (cadr lp) (angle (cadr lp)(last lp)) lt) ;; nuevo punto final
  11.  i 0 ;;; para solo cambiar el último punto
  12.  lead (mapcar '(lambda(a)(if (=(car a)10)(setq i(1+ i)))
  13.  (if (and (= i 3)(=(car a)10))(cons 10 pf) a)) lead)
  14.  ))
  15.  (princ "\nEntidad no encontrada")
  16. )
  17. )
Deputy dwg to run lisp
https://www.dropbox.com/sh/7kkt2zgdyjgbwwy/AAB1oH7LcnVVjjSGGz00ZYhLa?dl=0
« Last Edit: May 25, 2016, 02:19:47 PM by amc.dicsac »
