Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
CAD Forums
CAD General
Topic:
Annotative Block
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Annotative Block (Read 1714 times)
Fabricio28
Swamp Rat
Annotative Block
on:
February 21, 2014, 09:35:28 AM »
Hi guys,
I'm trying to insert annotative option in the block that doesn't have that option.
(without create the block again.)
Is it possible?
Thank in advance
Logged
Rob...
King Gator
Take a little time to stop and smell the roses.
Re: Annotative Block
Reply #1 on:
February 21, 2014, 09:41:58 AM »
Make note of the block name. Start block command, "B", and select the block from the drop down list in the top left. Check the "Annotative" box adn clikc "OK".
Logged
CAD Tech
Fabricio28
Swamp Rat
Reply #2 on:
February 21, 2014, 09:49:37 AM »
Thank you RobDraw,
Worked great for me.
I'll advise my friend doing that, because it is his doubts.
Regards
Logged
Krushert
Seagull
FREE BEER Tomorrow!!
Reply #3 on:
February 21, 2014, 12:02:31 PM »
The other option is to select the block and right click and select edit with the block editor > scroll down to the bottom of the property pallets > and check off the annotative option.
Logged
I + XI = X is true ... ... if you change your perspective.
Fabricio28
Swamp Rat
Reply #4 on:
February 21, 2014, 01:21:23 PM »
Hi Krushert,
Your option didn't work for me.
Could you attach a image, please?
Thank you
Last Edit: February 21, 2014, 01:25:21 PM by FABRICIO28
Logged
Krushert
Seagull
Reply #5 on:
February 21, 2014, 01:37:06 PM »
Your are not in the block editor mode. See Below.
Once in the mode, Select the options in the Properties Palette.
Logged
Fabricio28
Swamp Rat
Reply #6 on:
February 21, 2014, 02:04:26 PM »
Thank you Krushert,
worked too!
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
CAD Forums
CAD General
Topic:
Annotative Block
