Author Topic: -={ Challenge }=- Doomsday Algorithm  (Read 13190 times)
AIberto
Re: -={ Challenge }=- Doomsday Algorithm
« Reply #30 on: July 08, 2015, 08:49:49 AM »
Excellent  8-)
Dear Lee
I know the current Date  20150708 ,  3 days later is 20150711
I want know the Date at 200 days later... , How write this ?
Thanks.
« Reply #31 on: July 08, 2015, 01:17:17 PM »
This is probably the easiest way:
  1. (menucmd "m=$(edtime,$(+,$(getvar,date),200),YYYYMODD)")
AIberto
« Reply #32 on: July 09, 2015, 02:49:13 AM »
Lee, Inconceivable!
The current Date is Local time ?  Can I use your  Internet time function ? (LM:InternetTime "YYYYMODD")
« Reply #33 on: July 09, 2015, 06:45:24 AM »
Lee, Inconceivable!
Yes  :-)
AIberto
« Reply #34 on: July 09, 2015, 07:07:38 AM »
Lee ,Thanks,
But
like this ?
(menucmd "m=$(edtime,$(+,(LM:InternetTime "YYYYMODD"),200),YYYYMODD)")
? ERROR
« Reply #35 on: July 09, 2015, 08:43:40 AM »
No, you will need to either retrieve the Julian Date from the internet time server, add 200, and pass it to the edtime DIESEL function; or convert the date returned by my LM:InternetTime function to a Julian Date, before adding 200 and passing the resulting value to the edtime DIESEL function.
Lee
AIberto
« Reply #36 on: July 09, 2015, 09:45:11 AM »
Lee
Sorry , Lee , I can't understand.
AIberto
« Reply #37 on: July 09, 2015, 08:29:46 PM »
Lee , I think I understand that "Julian Date "
Thank you.
1.Manual Conversion
http://www.iasfbo.inaf.it/~mauro/JD/
DD/MM/YYYY 10/7/2015
==> Julian Day
2457214
_1$ (menucmd "m=$(edtime,$(+,2457214,200),YYYYMODD)")
"20160126"
2.  Conversion by function
_$ (setq tm (LM:InternetTime "YYYYMODD"))
"20150710"
_$ (setvar "userr1" (DTOJ (atof tm)));;  convert the date returned by LM:InternetTime function to a Julian Date
2.45721e+006
_$ (menucmd "m=$(edtime,$(+,$(getvar,userr1),200),YYYYMODD)")
"20160126"
_$
Lee, any suggest ? Thank you.
« Last Edit: July 10, 2015, 12:36:19 AM by AIberto »
roy_043
  • BricsCAD 18
« Reply #38 on: July 10, 2015, 04:01:14 AM »
Tip: Use strcat to build the string for menucmd...
AIberto
« Reply #39 on: July 10, 2015, 11:39:47 AM »
?? example ?
« Reply #40 on: July 10, 2015, 10:20:52 PM »
STRCAT
http://www.theswamp.org/~john/avlisp/#strcat
http://help.autodesk.com/view/ACD/2016/ENU/?guid=GUID-4430B1BF-DBB5-49D1-98F9-711B480976A1
What do you want the result to look like ?
What component pieces do you want to assemble ?
roy_043
  • BricsCAD 18
« Reply #41 on: July 11, 2015, 04:06:34 AM »
?? example ?
  1. (setq tm (LM:InternetTime "YYYYMODD"))
  2. (setq tm (DTOJ (atof tm)))
  3.   (strcat
  4.     "m=$(edtime,$(+,"
  5.     (rtos tm 2 0)
  6.     ",200),YYYYMODD)"
  7.   )
  8. )
AIberto
« Reply #42 on: July 11, 2015, 04:58:46 AM »
?? example ?
  3.   (strcat
  5.     (rtos tm 2 0)
  7.   )
  8. )
Very thanks ,roy , This is a good idea.  :laugh:
