Author Topic: All Support File Search Paths Exported to Notepad or excel?  (Read 1651 times)
TIMOTHY99C3D
I am in need of a lisp code that can capture all of the Support file pathes and put them into excel or notepad.  I found a post by Mark from years ago that does this for the "Support File Search Paths" but only the "Support File Search Paths"  Posts: 25108  http://www.theswamp.org/index.php?topic=442.msg5409#msg5409
This level of code is beond my curent level of understanding at this point.  I have over 200 profiles of users within my comany that I need to sort through and identify the common pathes for their small groups.  Being able to push them out of the (*.arg) files all at once would be a big help.
Thank you,
Timothy
dgorsman
Re: All Support File Search Paths Exported to Notepad or excel?
« Reply #1 on: June 02, 2014, 10:25:55 AM »
I'll make a lateral suggestion - do a quick sample (10 - 20) then work from there, creating paths where necessary.  Trying to reconcile that many different users
a) will take a very long time
b) is unlikely to be reconciled into a logical, easy to manage list
and c) will need to be adjusted later anyways
Support file search path is stored in a single registry entry ("ACAD") under the AutoCAD profile as a semi-colon concatenated string.  Its one of the easiest items to tease out of the structure.
try {GreatPower;}
   catch (notResponsible)
      {NextTime(PlanAhead);}
   finally
      {MasterBasics;}
GDF
« Reply #2 on: June 03, 2014, 10:54:09 AM »
(getenv "ACAD")
